[Logic Pro 9 & Artist Mix] Incompatible EuCon version at initialization
Hey guys,
When starting logic, I am confronted with this hideous incompatibility notice: Incompatible EuCon version. Please make sure that both Logic Pro and EuCon are up to date. Minimum EuCon build: 65916 And am given the options to either 'Launch without EuCon', or 'Quit'. Goes without saying that selecting the former simply starts Logic, leaving the surface unresponsive. - System and software information Logic Pro: 9.1.8 (1700.67) (32-bit) EuControl: 2.6.2 78202 System: Mid-2012 "15 MacBook Pro w/ Retina display (i7-2.7GHz, 16GB DDR3, 768GB SSD), running Mountain Lion (10.8.2). - EuCon and Artist Mix information MC Mix Protocol: 1.0 Firmware: 1.5.1 PCB Rev: 0 ID: MAC:##-##-##-##-##-## (hidden. tough luck. ) Artist Mix' connection to computer Surface is connected via an Ethernet cable to a 3rd generation Time Capsule (also acting as a router), which is connected via another Ethernet cable to the Thunderbolt display, and then the Thunderbolt display is connected via a Thunderbolt cable to the MacBook. When turned on, the Artist Mix is instantly recognized by EuCon, and is added to 'My Surfaces' (as 'MC Mix'). - Additional notes I've contacted Avid/Euphonix support (supplied by Brian of OBEDIA), and was told that there are incompatibility issues between the Avid/Euphonix Artist surfaces and the new MacBook Pro's w/ Retina display. These issues are, apparently, caused by the Thunderbolt to Ethernet adapters not playing nice with each other. I was offered the following workaround; Connect the MacBook to a wireless router, via wifi, and connect the surface(s) to that router. This does not work. I still receive the same incompatibility notice. Here's another _very important issue to point out_: Two days ago, I tried uninstalling EuCon from my system, by launching the 'Uninstall EuControl' app (found under /Applications/Euphonix/) and re-installing it from the .dmg, found on the Avid site. As always, the surface was instantly recognized, and when I launched Logic, it just worked! No notification, nothing. It just started, and the surface did it's part (faders went up according to tracks in the loaded project, moving them controlled faders in Logic, and vice versa). The surface was connected via the Thunderbolt display (not wifi!), as detailed above. This means that the Thunderbolt to Ethernet adapters function as intended. I thought I had it fixed! --- That was until I launched Logic again today, and was confronted by the very same incompatibility notification. - I'm at the end of the road here. It's been almost 6 months since the "15 MacBook Pro w/ Retina display saw daylight (and almost a year and 8 months since the introduction of the Thunderbolt interface on MacBook Pro's), and until now this issue has yet to have been addressed. Avid is not a 'buck-a-share' company, and I find it puzzling to think that they've been unable to allocate resources to patch this. Especially since a huge portion of their clientele are Mac users, and the new Retina models are very popular. - Would love to hear absolutely anything. Best, -w00fa |
Re: [Logic Pro 9 & Artist Mix] Incompatible EuCon version at initialization
Same problem here, had to upgrade to Mountain Lion this week, getting Eucon verion incompatible error messages when I launch Logic.
One would think that 4 months after the OS release that sort of issues would be fixed: beside my old Adobe CS3 and Jack osX, Eucon is the only software that didn't survive the upgrade from Snow Leopard to Mountain Lion, and I use hundreds of software. |
Thing is; EuCon _is_ compatible (i.e., it works), it's just buggy!
I had it running perfectly, after Uninstalling and re-installing 2.6.2. But, the next launching of Logic backfired. |
Maybe we (or I) just didn't do something right and they will have an answer on Monday. |
I just forwarded this thread to SQA for evaluation. Thanks JC |
So this isn't a known issue? damn.. Perhaps it's a combination of the two (rMBP & ML)?
Same problem over here. Just appeared all of a sudden after having Logic 9.1.8 and OSX10.8.2 running fine with Eucon. No changes or additions to the OS or software...odd.
regards Krzysztof |
Are you using the Retina model?
Hey guys
we couldn't reproduce on a Retina Display MacBookPro running Mountain Lion. Just FYI...Is there anything different about the new machine? JC |
I'm on a Mac pro 8 core 2.66/2010.
K |
Artist Control check EUCON version on page 74 | Audioartist | Artist Series | 1 | 04-18-2013 10:29 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
Reason: Incompatible library version: Pro Tools requires version 9.0.6 or later, but | Patrick H | macOS | 3 | 11-20-2012 02:46 PM |
EuCon 2.6.2 incompatible with Retina MacBook | beemer | Artist Series | 42 | 11-18-2012 09:06 AM |
Incompatible library version: CFnd provides version 7.2.0 | heshion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-24-2009 03:42 PM |
