Old 04-01-2003, 03:29 PM
neatguys neatguys is offline
Default asio driver and sonar
Ok after struggling with this I finnaly got the asio driver to work with Sonar.
First download the digi asio driver.
Install it and when prompted select the reboot option in the installer.
Next you need to get the 2 sonar upgrades.
They are 2.1 and 2.2.
Install them starting with 2.1 then 2.2.
Next in sonar go to options and then audio then
to advanced.Under the playback and recording select asio.
Close sonar and open it again and you should be able to use the 001 in puts and outputs in sonar.
Protools still rules!!!
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
ASIO Driver Problems with Sonar 8.0 and FL 8 scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-22-2009 03:43 PM
Help: Sonar can't find the 001 (even w. ASIO) tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-13-2004 12:39 PM
Cant get asio driver to work w sonar neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-30-2003 11:03 PM
Will ASIO work with Sonar?? mix2much 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-12-2002 08:44 PM
