PodFarm: Plug-In Window Half-Visible, Many Sounds Greyed Out
I've successfully loaded PodFarm (Free) and it works on any given track.
However, the plug-in window displays only half of the podfarm screen - on the right half of the window; the left half is blank. Moreover, over half the Pod Farm settings are greyed out. The plug-in functions fine in Live 5.2.2, complete window and full access to all the amp and fx settings. Any help? Please advise, and thanks. Blue Ridge
New (January 2016): MacBook Pro i7, 1TB SSD OSX 10.9.5 Glyph 1tb External HD 7200 002, Mbox Mini (both still working on OSX 10.9.5) (Mbox records well, static on playback. Output works through MBP headphone jack) External Acer 23" Screen Still waiting to choose and to install PT 10-11-12 Old system (still running): Mac G5 Dual 2.0, 5.5 gig memory 160 (main) & 80 (audio) gig internal hd's OSX 10.4.11 PTLE 7.1,CS10, 002 Console Reason 3.0, Live 5.2.2 |
Re: PodFarm: Plug-In Window Half-Visible, Many Sounds Greyed Out
the issue is the version of protools you are running. podfarm is new software, and will look right in ptle 8. i am running both 8 and 7.1 here on different drives, so i've seen what you mean.
Thanks!
As you can tell, my old G5 duo won't support PTLE 8 (well, i guess i could buy some more memory, but everything seems to be working so i'm not anxious to invite any weekend screaming sessions). It does mystify me that my old Live 5.2.2. sees all of the PF voices and FX, while the PTLE 7.1 does not. I thought that it was a "come on and upgrade" routine, but apparently not (since it's all there in live). i'll play around with it as is. when i have a spare four grand, I'll get that blazing Macbook Pro 2.93 with 8 gigs memory from Sweetwater. But not by this weekend.
Solved: PodFarm: Plug-In Window Half-Visible, Many Sounds Greyed Out
Well, it's rickety, but it works. Discovered by accident, of course:
1. On chosen track, select Insert-Plug-in-Other-Pod Farm. 2. Pod Farm plugin window will come up half-empty. 3. Click on the same insert button twice. First click - window disappears. Second Click -- window reappears with full view of Pod Farm window. 4. All sounds are also now available. Weird but it works.
Humm...not having an issue on this system here.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
Hummmm... that's because you are running PT8. did you read my original response to the first post?
7.3 Window configurations greyed out... | lebowski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-02-2007 11:37 AM |
How to keep Plugin Window Visible? | fader8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-08-2006 08:36 AM |
how to generate visible tc window in PT? | c-post | Post - Surround - Video | 8 | 12-05-2003 03:43 PM |
I can only see half of the wave in the edit window.....WTF! | Mikchek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-06-2003 08:06 PM |
Edit Window Display not completely visible | Douglas Audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-26-2002 10:14 AM |
