Bounce or Print
I use several VI and find issues sometimes,,, so instead of having several VI open want to make audio tracks.. is it better to print or bounce the track,
Would this also apply tp printing or bouncing a final mix before mastering? k
Wow am I groovy or what |
Re: Bounce or Print
Re: Bounce or Print
I prefer to Commit Up To the VI plugin so that I'll have an audio track to work with - mainly because I just prefer working with actual audio tracks when mixing. Plus, it's good to have the VI printed in case for whatever reason the VI becomes unavailable at some point. You still have the MIDI/Instrument track you can go back to if you Commit, the only downside is that if you make changes to plugins after the VI or have automation on the audio track, you have to make sure to copy the changes back and forth.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Re: Bounce or Print
So is there better quality if you print then bounce or the vice versa ?
Re: Bounce or Print
No. It’s just workflow. Sound is the same. Sent from my iPhone using Tapatalk |
Re: Bounce or Print
thanks,, I thought so but wasn't sure because someone told me printingthe track in real time was the wat to get all your automation correct and that bounce could mess up automation.
Re: Bounce or Print
I have had VI's audio messed up when bouncing a mix or even freezing or committing - like glitches in the audio or tails cut off - another reason I like to commit them to audio and make sure the audio track is perfect so that you don't have to worry about it later.
Bounce or Print in a Master Session with PT | kalony | Tips & Tricks | 2 | 04-13-2017 02:29 PM |
Mix, bounce to disc or print to audio chan. | JimmyM | Pro Tools 11 | 11 | 03-24-2017 01:24 AM |
PRINT vs offline bounce | stormmusic | Pro Tools 11 | 5 | 01-31-2016 05:37 PM |
Speed of Song after bounce/print to mp3 | eekamouse | Pro Tools 11 | 9 | 12-18-2015 08:03 AM |
Print/Bounce Tracks with Plug ins | gjohung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-23-2006 09:19 PM |
