Old 03-07-2012, 06:19 AM
Felix Andriessens Felix Andriessens is offline
Default Can't set Sync Anchor Points Pro Tools 10
Setting sync anchor points (cmd-,) doesn't work anymore for me. First I thought it had to do with read/write permissions, but consolidating regions doesn't change anything.
Anybody else experiencing this?
I'm working on a late 2011 iMac 3,4Ghz / Lion 10.7.3 / PT 10.0.
Old 03-07-2012, 10:14 AM
mixboy bob mixboy bob is offline
Default Re: Can't set Sync Anchor Points Pro Tools 10
Works fine here.
Did it stop working after you went to 10.7.3? That's not a supported OS. Just one thing to think about.
Also, all plugins up to date?
Keep us posted!
Rob Burrell
aka mixboy
http://www.robburrell.com
PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA
Old 04-04-2012, 12:26 AM
Thanks Rob, sorry for not getting back earlier: can't tell if it is a 10.7.3 thing as I my computer has never been on an earlier system version. PT10.0.1 doesn't fix it either. It might also be an permission thing; after Im done with the current project, Im going to check that.
Old 04-23-2013, 08:36 AM
jschmidtiii jschmidtiii is offline
I'm having the same issue. I think it's a PT10 issue? I just watched a tutorial on sync points and I don't even have the "identify sync point" option in my clips drop down menu; instead, I have "remove sync point", and apparently Cmd-, is the hotkey for that. I pressed it hoping that PT had just renamed the same functionality, but I don't see any blue arrow when I click "remove sync point" from the drop down or hit Cmd-, . Has anybody found a fix for this yet?? Thx.
MacBook Pro, OSX 10.7.5
2.26 GHz Intel Core 2 Duo
8 GB 1067 Mhz DDR3
Mbox Pro
PTX, M-Powered
Firewire 400 > Firewire 800 converter
Old 04-23-2013, 08:56 AM
Update:
Actually I just tried doing Cmd-, in the middle of the region and the sync point came up right away. I think the small gain fader in the bottom left hand corner of the region was blocking the arrow. Crisis averted!
Question About Sync Points tomhartman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-24-2006 07:04 AM
Automation and Missing Anchor Points New Hope Media Pro Tools TDM Systems (Win) 6 11-18-2005 03:08 PM
Lack of surround anchor points driving me NUTS! John@Fusion Post - Surround - Video 5 04-28-2003 07:49 AM
Sync Points: Moving regions according to Mount Royal Pro Tools TDM Systems (Mac) 7 08-15-2001 12:36 AM
PT5 sync points & nudging errors Farmer Dave Pro Tools TDM Systems (Mac) 4 02-14-2000 12:04 AM
