Old 09-08-2006, 05:14 AM
ruudman2003 ruudman2003 is offline
Default Updating firmware on SCSI drives in OSX (10.3.4)?
I have a couple of Seagate Cheetah ST336607LW drives, and an Atto UL3D scsi-controller.
I've had lots of troubles with this setup, and I suspect my drives need to have updated their firmware (they both have Rev:0004).
Anyone know how to update firmware on SCSI drives in OSX (Panther)??
Or better: has anyone the same setup that works?
My setup:
G4 QS 2002, 933, OS 10.3.4, 1,5 Gb RAM
Atto UL3D Ultra 320 card
Seagate Cheetah ST336607LW Rev:0004 drives
HD2
PT 6.7 cs8
Thanks,
ruudman
Old 09-08-2006, 09:26 AM
Eric Seaberg's Avatar
Default Re: Updating firmware on SCSI drives in OSX (10.3.
We've got 4-HD systems and 14 of the 73GB version of that drive in Rorke 'sleds'. We've never had a problem with any of them in 2.5 years. Have you confirmed the firmware and settings of the Atto card?
Eric Seaberg • San Diego, CA
Old 09-08-2006, 12:17 PM
I use the Atto firmware suggested by Digidesign. Same goes for drivers, config tool, atto preferences; all according to PT 6.7 requirements.
Anyone who use Seagate Cheetah with Pto Tools? Please let me know if you have a newer revision of the disk..
BTW, thanks for answering. Eric
ruudman
Old 09-08-2006, 12:53 PM
minister's Avatar
minister minister is offline
hi i have the UL3D. ATTO config 3.06, driver 3.2.1, flash 1.6.6f0
all my cheetahs are rev 0006
don't know how they got that way...maybe the ATTO updates did that.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 09-08-2006, 01:12 PM
Thanks, Minister!
But according to Digidesign, your ATTO specs are too recent for my PT6.7 on Panther..
What PT/OS are you running?
I don't have a clue if updating ATTO does something with the harddisk firmware, but I suspect it doesn't.
The disks having Rev. 0004 is making me quite nervous right now, having read in a Unix forum that there was some trouble with Cheetahs...
ruudman
Old 09-08-2006, 01:21 PM
minister's Avatar
yeah, i am on 10.4.6 and PT 7.2...
call ATTO, i found them very helpful when i had an issue.
Tom Hambleton CAS
IMDb
-Starcrash
Old 09-19-2006, 07:16 PM
David MacKenzie David MacKenzie is offline
We have an HD3 on a G4, which had great SCSI performance with 5.3.1 on OS9, but never ran very stably or performed well with Pro Tools HD 6 on Panther or Tiger. (Firewire drives were OK on OSX, though.)
Once Pro Tools HD 7.1 came out, SCSI performance became good again and rock solid. We have a mix of five 10K drives including a Seagate or two, and have that one ATTO SCSI card that Digi currently supports.
Your problems might well go away if you upgrade to Pro Tools 7 (7.1 at least; I don't have 7.2).
Old 09-19-2006, 08:54 PM
Ginger Ginger is offline
I have the same setup as you except my QS is 733. Been running OS X 10.3.8 PT 6.9.1 for sometime with ATTO & cheetahs with no problems. However, I do have some older Cheetahs that won't mount under OS X. They mount fine in OS 9. I know this is a drive firmware issue, but I also do not know how to update the firmware. I'm guessing it's PC only (?) as most firmware flashes are (except on stuff specifically for mac).
I don't use them much so I've never pursued updates. I'd try calling Seagate and see what they say. I'm sure they're useable just don't know how to update them.
At least you know it's not just you or your other stuff or settings.
Good Luck and please let us know if you find anything out.
Old 09-20-2006, 01:11 AM
Richard Barrie Richard Barrie is offline
I have discovered that with older drives it is worth upping the "Selection Timeout" setting in the Atto configuration tool. As I remember the default is 50mS and this is sometimes not long enough for older drives to report themselves as present. I have never had a problem when set to 250mS.
Old 09-25-2020, 01:52 PM
BCM BCM is offline
Default Re: Updating firmware on SCSI drives in OSX (10.3.4)?
Hi I have some old drives I need to get some sessions off off but I sold my old G4 & G5 13+ years ago but I found my Digidesign SCSI 128 card but no drivers If so one can let me know if this card works best with a G4 or G5 that would be great Thank you.
Colin Miller
B.C.M Recording
Updating firmware time_ghost Pro Tools HDX & HD Native Systems (Mac) 4 12-30-2013 02:04 AM
Firmware in 002 rack not updating Scottyman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-03-2009 07:29 AM
Problems updating firmware JessAvery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-27-2009 06:44 PM
Firmware not updating cjbeckius 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-15-2006 11:47 PM
firmware updating stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-19-2004 03:01 AM
