Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-02-2020, 12:59 PM
jseelye02 jseelye02 is offline
Default 2020.3 High Sierra - Mac 5,1 - No Video playback
Anyone else having issues with their Mac 5,1 running High Sierra NOT playing back ANY QuickTime files after upgrading to 2020.3?
I've tried 4-5 codecs, they all import fine but won't show frames or playback (just a black screen).
Multiple restarts, updated codecs, etc...
I've been using the same machine with 2019.12 for a while with no issue, this all happened after the upgrade.
All the movie files I have open fine in QuickTime and MPEG Streamclip.
Anyone else?
I've downgraded to 2019.12, everything works fine right now with that, but I'd like to sort out 2020!
Old 04-03-2020, 03:41 PM
Default Re: 2020.3 High Sierra - Mac 5,1 - No Video playback
Solved it, adding it here in case someone else runs into this issue:
Go to /Library/Application Support/Avid/AVX2_Plug-ins and empty the contents of this folder if any.
Go to /Users/Shared/AvidVideoEngine and delete this folder.
Restart PT, works immediately.
Old 04-03-2020, 08:19 PM
sw rec sw rec is offline
Thanks for the insight. Having similar problems on Win 10. I’ll give your suggestions a try tomorrow...nothing to lose, it already doesn’t work!
Old 04-27-2020, 03:25 PM
Avid tech support suggested that fix...when I tried it, Pro Tools wouldn’t launch. Had to reinstall PT. I have a tech support call scheduled for tomorrow morning, will let you know what we find.
2020.3 on Mac Pro 5.1, High Sierra? audioluche Pro Tools 2020 28 04-03-2020 01:56 PM
PT 2020 to require Mojave and drop High Sierra support? XJENSEN Pro Tools 2019 10 03-28-2020 11:54 AM
Video Card - Mac Pro High Sierra & Native Siegfried Meier Pro Tools HDX & HD Native Systems (Mac) 46 02-03-2019 02:26 PM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
12.8.2R2 on High Sierra TrentWilliams Pro Tools 12 3 10-21-2017 10:09 PM
