PT9 with Projectmix i/o & Liquid Saffire 56?
Hi Im running a M-Audio Projectmix with ProTools9 and want to upgrade my audio interface to a Focusrite Liquid Saffire 56, but i still want to use my projectmix as a control surface and as an 8 channel preamp. Is this possible and how would i go about it? (My computer is a macbook pro)
I have trawled the forums already with little information to help me, so any bit of help is greatly appreciated. Cheers R. |
Re: PT9 with Projectmix i/o & Liquid Saffire 56?
Hey master-fader,
The LS56 is capable of dual unit performance via firewire. Connect the LS56 to your computer with the "Firewire 1" port, and then simply plug the ProjectMix IO into the "Firewire 2" port into the back of your LS56. This worked for my Pro 40, and I'm assuming the same for the LS56 (both capable of dual unit operation via firewire). I realize this is a tad late, but since this thread popped up in my Google search, hopefully it will help the next guy. =) Joseph |
You cannot connect the Saffires with the Project Mix in this way. You may be able to run them on the same firewire bus, but not as one interface.
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Hey Katherine,
Sorry for the misguiding post. Pro Tools would not recognize both interfaces when I had them plugged into my 3-port firewire card, but it does when I route the ProjectMix (used solely as control surface) through the Pro 40 via the extra firewire port. You are correct though, it does not treat them as one interface. On that note, do you have any idea as to why that is? Thanks! |
I was actually able to run both my ProjectMix I/O and the Saffire Pro 56 together by buying a second firewire card. By running each on a separate Firewire card, they run just fine. As far as co-existing on the same Firewire bus, ProjectMix I/O has never played well with other devices on the same bus.
jgbsound Quote:
On a Mac, you might be able to setup both as Aggregate, but on a PC, I believe you would need to use the ProjectMix as your PT interface, and connect the LS56 via lightpipe(would show up in PT as the ADAT inputs 9 thru 16). Then you would need to run the LS56 software and route the 8 mic preamps to the lightpipe output.
Liquid Saffire with Projectmix as controller | master-fader | macOS | 6 | 08-06-2013 04:33 PM |
Pt 10+ liquid saffire 56+ saffire pro 40 masterclock? | Nightworker | Pro Tools 10 | 16 | 12-08-2012 10:29 PM |
saffire pro 40 vs liquid saffire 56 | AxeDye | Pro Tools 9 | 9 | 12-09-2010 05:19 PM |
Projectmix I/O Or FOCUSRITE LIQUID SAFFIRE 56 | master-fader | Pro Tools 9 | 7 | 11-21-2010 06:18 PM |
liquid saffire 56 | AxeDye | Pro Tools 9 | 2 | 11-19-2010 04:28 PM |
