Old 03-30-2005, 10:47 AM
zilby zilby is offline
Default Plugins for Pro Tools LE vs Pro Tools HD question?
Hi. I am not fortunate enough to have Pro Tools HD (yet), but I have been using Pro Tools LE, and I love it. I have been looking at different plug ins (for instance the Waves Bundle), and I noticed that there is a price difference (the HD plugins are more expensive). I was wondering if the same plugin written to work with Pro Tools LE working at at sample rate of 96KHz (with my CPU doing all the work) will have the same outcome with the same (but more expensive) plugin for Pro Tools HD working at 96KHz (the the HD Core Card doing all the work).
I guess my question is the result of a plug in the same? And if so, why are the HD plugins more expensive?
Old 03-30-2005, 10:52 AM
rockrev rockrev is offline
Default Re: Plugins for Pro Tools LE vs Pro Tools HD question?
True TDM plug-ins are designed to work at 48-bit fixed, whereas RTAS plug-ins run at 32-bit floating. TDM plug-ins are more accurate (bit for bit).
rockrev
End world poverty: ONE
Old 03-30-2005, 10:54 AM
Riad Riad is offline
With the exception of a few plug-ins I would say you wouldn't be able to tell the difference. For me the big difference is on the TL-Space Reverb for Accel, McDSP Analog Channel and the UA 1176 Compressor plugs for TDM.
You can keep your Waves LE plug-ins when you upgrade, they will install and work with an HD system, however, the only limitation there is that RTAS plugs need to be first before appying any TDM plugs, not a huge deal.
Why the TDM plugs are so much more expensive is a very good question.
www.carvelstudios.com
Old 03-31-2005, 08:05 AM
Thanks for your help.
Updated to Pro-Tools 10.3.6 Now Pro-Tools won't load plugins and audio suite plugins nyspaz macOS 1 07-27-2013 02:16 PM
Pro Tools 8 LE to Pro tools 9 crossgrade question MKZ macOS 5 04-27-2011 11:38 AM
Pro Tools 8 to Pro Tools 9 Session question Caatalyst Windows 3 03-24-2011 01:05 PM
pro tools le plugins B1gun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-04-2011 10:46 PM
Protools M-Powered Plugins & A Projectmix/Pro-Tools Question Rufalo Pro Tools M-Powered (Mac) 1 05-02-2009 07:13 AM
