Old 06-26-2018, 05:05 PM
bropecia bropecia is offline
Default HD 9, Komplete 11 Ultimate, & 6 Core 3.33Ghz?
Hi guys, I have (2) blue 192's, Control 24 and an old Power PC G5. Retiring the G5.
I'm planning to buy a : 5,1 6-Core 3.33Ghz Westmere 32GB 1TB ATI 5770, along with the cards below (minus one accel):
https://www.ebay.com/itm/Avid-Digide...19.m1438.l9372
I'm assuming that... HD 9 will keep my control 24 alive, and some of my old waves plugins still working, OS 10.11 will enable Komplete 11 and HD9 to be happy together, and my digilink cables will connect up to the Pcie cards without trouble.
I want to use this for composing/scoring to picture.
I know there's better out there, but there seem to be enough people endorsing the six core and the price is right so...
Am I good? Or am I missing anything?
thanks for any insight!
Old 06-28-2018, 01:14 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Re: HD 9, Komplete 11 Ultimate, & 6 Core 3.33Ghz?
Be aware of the system requirements for PT HD9, it will not work on OS 10.11, see http://avid.force.com/pkb/articles/e...ility/en380531 and http://avid.force.com/pkb/articles/e...ility/en436391.
So maybe you will need to make one partition with 10.6.x or 10.7.x for HD 9 and one partition with 10.11.x (or higher) for Komplete 11.
If you want to use PT and Komplete 11 together you will need Pro Tools 12 but Pro Tools 12HD (now called Pro Tools Ultimate) will not work with TDM cards, only with HDX card(s).
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
System 1: Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.13.6 - Magma EB7 - PT HDX3 - PT Ultimate 2018.12 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x3)
System 2: Mac Pro (Mid 2010) 3.33 GHz 6-core - 32 GB RAM - OS X 10.9.5 - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192D I/O - SYNC I/O
Old 06-29-2018, 01:01 PM
Okay great, thanks a million for the heads up.
Hmmm. From a cost perspective, Wondering if I can just score to picture with the westmere using komplete 11 and protools 12 vanilla and then pipe everything over to my g5 tdm PT 7.3 for mixing? I’m just not sure how far I can push vanilla with komplete and a few audio tracks, and then also whether the method for session transfers would be a headache, etc.. maybe I just need to bite the HD Native bullet. Dunno.
Old 06-29-2018, 03:27 PM
Originally Posted by bropecia View Post
Wondering if I can just score to picture with the westmere using komplete 11 and protools 12 vanilla and then pipe everything over to my g5 tdm PT 7.3 for mixing? I’m just not sure how far I can push vanilla with komplete and a few audio tracks, and then also whether the method for session transfers would be a headache, etc.. .
You will be able to push PT 12 vanilla with Komplete 11 and a lot of audio tracks very far on a Mac Pro 6 Core 3.33Ghz., especially for mixing. It will run in circles around your G5 TDM PT 7.3.
I don't see any reason why you should continue using your G5 TDM rig other than for live multitrack recordings without latency.
Marc Schellekens
Old 06-29-2018, 08:10 PM
Thanks, and yes I agree about the tdm g5, I just like the
Control 24 surface for mixing, that’s the only reason! Appreciate your help.
Old 06-30-2018, 05:07 AM
Well, that should not be a problem. Neyrinck has a new version of V-Control Pro that supports Control 24 and ProControl in Pro Tools 12 by the HUI protocol. Take a look at https://neyrinck.com/v-control-pro/.
And I know it really does work, because I'm one of the beta-testers of this new version of V-Control Pro. However I tested ProControl functionality, not Control 24, but I'm very confident Control 24 will work fine too.
Marc Schellekens
Old 06-30-2018, 09:39 AM
Music to my ears Marc.
Old 06-30-2018, 03:27 PM
A small advice with large consequences:
Change all the HDD drives in the Mac Pro 6 Core 3.33 GHz to SSD drives, for example Samsung EVO 860 1 TB SSD drives. It will make your Mac Pro with Pro Tools 12 and Complete 11 Ultimate very fast.
Marc Schellekens
Old 07-01-2018, 12:48 PM
Yes!! I’m excited to get it all up and running next week!
Problems upgrading Komplete 8 to Komplete 10 Ultimate in Pro Tools 10.3.9 Freddysdead Pro Tools 10 17 02-12-2015 01:46 PM
Komplete 8 Ultimate paldry Pro Tools Software (Mac) 1 12-06-2011 07:42 PM
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann Pro Tools Software (Mac) 4 02-18-2011 07:08 PM
6-core (3.33GHz) or 2 quad-core (2.4GHz) Westmere Detlef Brockmann Pro Tools TDM Systems (Mac) 7 02-18-2011 04:57 AM
2010 mac pro 2.4Ghz 8 core vs 3.33Ghz 6 core edadema Pro Tools TDM Systems (Mac) 32 09-07-2010 07:36 AM
