Old 05-23-2018, 06:04 AM
bruce lang bruce lang is offline
Default "Not able to save session/volume not found" fix
Using PT 10 HD-3 on 2012 Mac, every now & then I get a message that session could not be saved, or backed up/volume not found. It goes away after a while but can hold things up, and don't know if it's a Mac or PT problem. I've discovered that if I just "Hide Pro Tools" then un-hide it, I am able to save as normal!
Old 05-23-2018, 09:23 AM
albee1952 albee1952 is online now
Default Re: "Not able to save session/volume not found" fix
Is the session running on an internal drive or external?
HP z820 12 core, 64GB RAM, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs, Warm Audio and Midas..............................
Old 05-23-2018, 03:49 PM
Internal SSD. it used to do the same thing occasionally with another SATA Internal. Doesn’t happen often, but glad to discover the quick fix!
Found a workaround for "Save As" Elbergo Pro Tools | First Discussion 0 10-12-2017 01:12 AM
PT10 : Volume automation disabled after "Save copy In" brenny Pro Tools 10 2 06-18-2015 02:33 AM
Save as > "Could not 14404 because File or folder not found (-43) while opening "..." Elias Stiza 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-10-2012 07:06 PM
Can't Save, I get "Audio Record Volume Message" elijahtrotsky General Discussion 1 03-10-2009 08:44 AM
emergency. "error 35-Volume not found". rjd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-28-2009 05:24 PM
