Old 11-10-2004, 03:10 AM
AKA AKA is offline
Default Re: Logic into Protools. An idea for someone to steal.
We achive the same effect using a similar method;
The way it is done here is by using a RME9632 (dual ADAT card) for LAP and feeding the outputs of the card into an Adat bridge.
Hence having 16 busses fed from LAP to PT. works great !
Transport is controled from PT using MMC.
DesignInSound
Old 11-10-2004, 03:26 AM
MarcoM MarcoM is offline
I haven't tried that, as I don't have a G5 available, but in principle it should work.
On my iBook with an MBox I can get Logic to use the standard CoreAudio driver and output from the headphones minijack socket, and I can plug it into the analog input of the MBox to record in in ProTools. Aside the audio quality, though, I still have to deal with the latency. The IAC side of things works perfectly if ProTools is master and generates MTC. I suppose I could get a FireWire interface to run with Logic and go SPDIF into the MBox, but I would rather avoid having to spend more money and also having to deal with latency issues.
I'm still investigating the VST to ReWire issue, perhaps Jack's VST plug could be wrapped for ReWire instead of RTAS, and that might make it work.
Marco Migliari
Producer, Mixer, Engineer, Mastering
www.marcomigliari.com
[email protected]
Old 01-20-2005, 12:51 PM
pablovius pablovius is offline
I'm trying this IAC/MMC scheme to trigger Logic 7 Instruments form PT. (Alas, I'm a Logic newbie) How can one configure IAC inputs to Logic Instruments on the Logic side? (There is no IAC mention in the ever-so-turgid Logic manual)
TIA
Old 03-30-2018, 11:17 AM
RGrierson RGrierson is offline
You can bus Logic Pro audio output or any core audio Application like MainStage, iTunes Digital Performer ect.. using Source Elements Nexus
https://source-elements.com/products/source-nexus
Its a Core Audio driver that connects to a AAX plugin in ProTools
Select the Source Nexus Driver in Logic Pro's output page then load the
Source Nexus plugin in you ProTools session. Use the IAC bus to send MIDI from ProTools to Logic and your good to go.
Since its a AAX you will need ProTools 10 or higher
For older versions of ProTools It may work with the VST to RTAS wrapper or BlueCat PatchWork but I have not tested that config
Focusrite Scarlett - A Steal! RussUK General Discussion 45 05-12-2010 03:29 PM
Dear Digidesign, Please steal this Nuendo feature! Borg Pro Tools TDM Systems (Mac) 22 05-02-2008 01:32 PM
Logic into Protools. An idea for someone to steal. John Tooker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2004 06:09 AM
ADAT, steal it now.... msog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-12-2003 05:43 AM
Best idea yet for next protools software Redbeard Tips & Tricks 5 01-11-2002 07:36 AM
