  #21
Old 01-24-2013, 02:55 PM
Fish Horse Fish Horse is offline
Default Re: Video playback becomes slow and jerky.
Are you sure everything is fitted tight enough in the pci-slots? I've moved my cards in and out hundreds of times without a problem. There should be a way to have it up and running again. Disconnect from mains again and double check.
Btw Avid recommends fitting BM cards in slot 3.
About the no video output on hdmi problem: Try to load a quicktime that came with the BM software into ProTools. Probably the BM card doesn't support the QT format of your specific .mov. I always convert with "mpeg stream clip" (free pgm) to Motion JPEG MJPEG also called Photo JPEG (High Quality QT format with lowest tax on cpu). But the best thing is to ask the editor to provide you with a mjpeg QT.
Good luck, hope nothing is broken there...
  #22
Old 01-24-2013, 03:01 PM
http://duc.avid.com/showthread.php?t=305669
http://avid.force.com/pkb/articles/e...ssage/en210585
worth checking
  #23
Old 01-25-2013, 12:58 AM
Felix Rost Felix Rost is offline
Try SD video - or - select "Down Conversion.." option in Blackmagic Driver in system settings to determine if it is a compatibility issue with your monitor. I had one system where it only worked with down conversion even though BM player could make it work..
  #24
Old 01-25-2013, 10:45 AM
Sonny Keyes Sonny Keyes is offline
I'm using a Blackmagic Intensity Pro in Slot 4 - the monitor display card is in Slot 1 and the Digidesign cards are in 2 & 3. My main screen is driven via HDMI and the crappy tube TV in the booth gets the Composite out. That means if the voice talent needs to see picture I have to convert to 720x480 anyway because the Composite can't handle HD, so it's just become part of the routine.
  #25
Old 06-10-2018, 10:18 PM
espantalho1 espantalho1 is offline
If you're on a Mac, go to Mac HD>Applications and right click on Pro Tools>Get Info>check "open in low resolution". That seemed to help.
video playback jittery jerky stuttery hedgerocks Pro Tools Software (Mac) 17 11-26-2013 09:37 PM
Jerky video playback peter5992 Post - Surround - Video 3 08-02-2012 11:05 AM
PT9 on mac pro. Jerky QT video playback!? Sawdust Pro Tools Software (Mac) 5 04-18-2011 10:25 PM
Video Playback Very Jerky slinky005 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-14-2009 07:14 PM
PlayBack Slow with Video media_kar Pro Tools TDM Systems (Mac) 7 01-11-2009 10:10 PM
