Old 04-19-2009, 10:27 AM
manley manley is offline
Default Pitch bend
Does anyone know how to pitchbend up or down by more than 2 semi-tones?
Thanks
Old 04-19-2009, 11:12 AM
andyj4308 andyj4308 is offline
Default Re: Pitch bend
This may help you:
http://duc.digidesign.com/showthread.php?t=225256
I asked the same question a little while ago. Vari-Fi is the easy easy option, if you don't have it then use Elastic Audio (Look at audiogeekzine's post).
Old 04-19-2009, 12:17 PM
flommer flommer is offline
Thanks
Are you talking about a mIdI instrument? If so, which one?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 04-21-2009, 01:05 PM
I'm having the trouble using a midi instrument, as opposed to audio. The sound I'm using is a sax sound. When i've tried to draw out the pitch bend on the track view selector, but it only allows me to draw the pitch bend up or down by two semi-tones. However, i need to pitch bend notes of the sax sound by up to an octave at times.
Does anyone know a solution?
Old 04-21-2009, 04:03 PM
Repeat.... Which MIDI instrument? What plugin?
Old 04-22-2009, 12:31 PM
Plugin: XPand
Instrument:soft tenor sax
Old 04-22-2009, 12:55 PM
ankely ankely is offline
Cool Re: Pitch bend
Manley,
To get more than the two semi-tones your getting, you will need to go into Xpand and reprogram the pitch bend. See Pro Tools Creative Collection Plug-ins Guide pg. 58.
Hope this helps.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2.
It is what it is...
ScrewMakerMusic
Old 04-22-2009, 01:05 PM
It's easier in Xpand2 (PT8) than it is in Xpand (for older versions)..
There is a thread in the VI forum, where I think Filosofem listed how to do so in the older version..
In Xpand2, one of the fields is labeled "PB" and it usually defaults to 2... Just change 2 to whatever you need...
Old 04-22-2009, 07:08 PM
You need a RPN and NRPN supported device.
filosofem
Old 04-22-2009, 08:24 PM
[email protected] Ebizseller@hotmail.com is offline
For me, using sampletank as my synth, i go to the synth control and change bender to whatever value i want. Which synth program are you using? the control to change your pitch bend value should be in this program somewhere
Pitch bend bug? Help!!! StinkyStan Virtual Instruments 13 12-20-2016 12:32 AM
Automating Pitch Bend WhiteRhino macOS 1 12-09-2012 02:33 AM
i want to bend pitch further sethwudel Pro Tools 10 4 10-01-2012 04:29 AM
Pitch Bend on Mac On PT LE Drags 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-20-2010 08:27 PM
pitch bend JimLap Tips & Tricks 1 04-01-2008 12:53 PM
