Old 01-22-2008, 09:54 AM
teacherman teacherman is offline
Default Plugin Windows keep Popping Up
I can't figure the logic out on this. PLEASE HELP. Please make this stop!
Evidently, I have some Preference Enabled that makes all the plug-ins on a certain channel(s) to popup and tile over the window whenever I make some kind of mouse-move and/or mouse-click over some certain area around the mix window.
Sorry, if I am not describing the problem clear enough. It's kinda like telling the doctor "it" hurts, but you're not able to the doctor where it hurts.
PT 7.3.1 cs5
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 01-22-2008, 01:02 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Plugin Windows keep Popping Up
PT 7.3.1 cs5
Hold shift whilst closing them all down one at a time. see if that helps!
Check your shift key hasen't become sticky!! opening a plugin whilst holding shift will open a plugin and switch off target mode for that plug! so it will stay open.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-22-2008, 02:26 PM
Okay, I just repeated this 'problem' three times in a row.
All plug-ins on a channel will popup when I create a new AUX send on that channel.
How do I stop the plugins from popping up?
Thanks,
Old 01-22-2008, 03:04 PM
crizdee's Avatar
Thanks,
First try opening a new session and using import session data to import all the tracks from the said session into a new session! does that fix it? could be session corruption!! (there's no feature for this!!!)
That doesn't work then try this...
Use this app to backup your prefs then delete them all and see if that fixes it?
http://duc.digidesign.com/showflat.p...part=1#1116324
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-21-2008, 12:38 PM
This is still driving me crazy. Some one please make it stop!
Every time I click on an AUX send to make a simple volume change, any plugins that are inserted on that channel will popup.
If more than 1 plugin is inserted on that channel, the plugin that will popup is last plugin that was recently selected.
Is there a Preference that is accidently turned on that is making this keep happening?
Thanks.
7.3.1 cs5
Old 05-21-2008, 01:02 PM
Craig F Craig F is offline
do you have an ICON on the system in Focus mode?
Thank you,
Craig
Windows 7 update of M audio pro tools 8 and now I have popping. Intuition Pro Tools M-Powered (Win) 6 05-29-2011 07:56 PM
Plugin Popping with automation enabled? rob shelby General Discussion 1 09-22-2006 03:52 PM
Plugin windows DannyVanSpreuwel ICON & C|24 0 09-15-2004 05:30 AM
HELP... T-racks EQ plugin "popping"?!?! minor2nd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-23-2004 06:39 PM
Getting Plugin windows to pop-up (5.1) JaredVogt ProControl, Control|24, Command|8 1 03-09-2001 08:17 AM
