Mbox 3: no signal going to left channel in L/R master
Following an upgrade to El Capitan, I'm not getting any sound out of the left output (not just playing from ProTools but in anything I run through the Mbox). As the attached image shows, this seems to be happening at source, i.e. it ain't the headphones - the signal going out of returns 1 and 2 are as should be, but they're only coming out of the R channel in the master mix.
Have messed about with Audio Midi Setup and settings in the Mbox controller (limited though both are) to no avail. Is this a driver problem? Is it time to get a new interface? Any ideas would be grateful received. With thanks, James |
Re: Mbox 3: no signal going to left channel in L/R master
Oh another brave El Capitan user. Now why did you ever upgrade to that?
Did you do an in-situ upgrade or a full new clean OS X install (like Avid recommends for OS X upgrades)? What exact driver version are you running? You do an uninstall and reinstall of that driver after the OS X (in-situ) upgrade? Some tests to try... Try is to use hardware monitoring of a source and see if you can get that to come out of both output channels. Pan both software returns to the left and see if anything come out on the L main out. That at least hints at where internally things are screwed up, even if you can't do anything about it... Boot back to your saved previous OS X image and test if it still works there. You did make a bootable backup right? Test on another computer. Install a clean OS X version (ideally not El Crapitan) on a spare drive or partition, install just the correct driver version for the Mbox 3 and test if that works from iTunes or similar. Last edited by Darryl Ramm; 05-26-2016 at 03:35 PM. |
Mbox 3, headphone out not playing left channel | jbs16 | FireWire & USB Audio Interfaces (Win) | 0 | 01-19-2015 05:40 AM |
Mbox Pro Headphone Outs Left Channel Only | maxlor314 | FireWire & USB Audio Interfaces (Mac) | 2 | 04-04-2013 04:53 AM |
Im getting a much stronger signal on my left side of Master Fader while Im in record | shamanrock | Windows | 0 | 04-12-2012 10:56 PM |
Left channel output louder in Mbox 1, please help. | pcmusicpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-14-2008 09:40 AM |
Lost the Left Channel OUT of my Mbox | Deirdre B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-30-2008 10:19 AM |
