How to allocate memory?
I'm using a PowerMac G4 400mhz with the 001 and Protools LE. When I try to record more than 6 tracks at the same time the G4 tells me that I need to allocate more memory to Protools. How would I do this?
Thank You |
Re: How to allocate memory?
Hello Smakrabbit,
1. Locate the Pro Tools application program . This is locted in the Digidesign folder that lives in the Mac hard drive. 2. Click the Pt icon only once. It should now be highlighted....then 3. Press Apple -i, and the Pro tools info box will pop up on the screen,....then 4. In the Show window, choose memory, then... 5. In the preferred memory, enter the new amount of memory that you want to re-allocate.,...then 6. Restart....and you're good to go... I use 250,000 Kenny [img]images/icons/smile.gif[/img]
my webpage |
I would suggest you increase the memory by f.ex 20.000 first, and if the problems persist, another 20.000, and so on. There is no point to giving PT much more memory than it needs.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I'm guessing he meant restart PT-- not the mac.
There's no reason not to give your apps as much memory as you can-- the more the better. Things will generally run smoother with fewer bottle necks with more. Just make sure you leave enough for the system to run comfortably (80-100mb). Of course, this all depends on how much RAM you have to begin with. You can also increase the amount of memory allocated to DAE (System/DAE Folder/DAE) using the same method.
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
The Mac DOES need to be restarted when changing memory settings of ANY kind in order for the new settings to take effect. I'm assuming we're talking about OS 9.
In OSX, memory is automatically and dynamically managed by the OS and there are no user settings that I can see so far... dk
www.dpksound.com |
While having enough memory allocated to perform the tasks required, allocating mroe than that, at least to PT and DAE, we found was actually detrimental. We experimented with settings and found 250mb for PT and 200 for DAE to be optimum, and allocating more than 100mb over these marks resulted in decreased performance, while allocating more up to the 100mb over mark gave no increase in performance, all based on the DAVEC test. Hope this is helpful. |
I've been that for so long I never knew or checked that we don't need to do that anymore. I hope that, that could not have always been the case, right? If it is, then I sure restarted way too many more times in my life than I needed to… [img]images/icons/shocked.gif[/img] I do know that you need to restart after making changes in the control panel, um, I think.. dk
www.dpksound.com |
Why Can't I allocate more memory? | AINSLIE | Pro Tools TDM Systems (Mac) | 12 | 01-03-2008 08:55 PM |
How does one "allocate more memory to DAE"? | Allbaldo | Pro Tools TDM Systems (Mac) | 5 | 09-26-2005 09:28 AM |
Memory is Low? Quit and Allocate more memory to PT | Unite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2004 05:38 PM |
How do I allocate more memory | soma323brooklyn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-16-2003 05:35 PM |
Help!! Allocate memory? | Craig Woolard | Pro Tools TDM Systems (Mac) | 1 | 03-26-2002 03:19 AM |
