PRO TOOLS 10 - initialization error code: -7
Hi Everyone, since 2 days now I am getting this error message when I start pro tools 10, firstly I was in 10.3.2 version of Pro Tools so I was wondering maybe I should update to 10.3.4, so I did update the software.
Same error message. The software is still working and the eleven rack too, just I dont know what does this message means, so I would like to fix it before recording again. If that can help here is my system : windows seven 64 bits Eleven Rack Pro Tools 10.3.4 |
Re: PRO TOOLS 10 - initialization error code: -7
Also I forgot, after I click OK I get this new error message the english translation would be :
Impossible to create the default value of TCE plug-in because a DAE error have occurred. Error DEA 0 have occurred ..
Windows seven 64 bit Eleven rack with Pro Tools 10.3.4 |
Before you get attacked for not posting a SANDRA REPORT... try THIS:
1. Completely uninstall protools (choose the uninstall option that completely removes, HD driver, preferences, Avid effects etc. **do not choose the remove protools only option 2. Reinstall 10.3.4 ...and Always Run as Administrator If no help then: Repeat steps but also Uninstall virtual instruments and then reinstall as well. 3. Make sure you have optimized your Windows 7 system according to Avid's Specs Let me know! Good Luck
Windows 7 64 Ultimate: SP1 PT 10.3.8 ------------------------------------------------------ ¨WHERE´S MY CHECKBOOK?¨ https://soundcloud.com/louieshowers |
I am having the exact problem wth PT 9.06 Native in Win7 32bit. I have uninstalled and reinstalled to no avail. The dongle seems fine as it will launch my laptop PT 9.06 no problem.
Personally, I thought 9.0.6 sucked. I would get 9.0.3 and try that
I fixed this by removing comodo firewall...
http://www.youtube.com/user/mixinginthebox?feature=mhee |
Hi Everyone, thanks for your replies, firstly I would like to apologize if SANDRA REPORT is compulsory I will try to make one later so you can get more in,formations if that could help, also after getting an update after checking the report I will try the thing about removing the pro tool and reinstalling it.
@rayg : thanks I will check right now.
hi Here is the Sandra report. SiSoftware Sandra ID Nom de l'Hôte : Death-PC Groupe de Travail : WORKGROUP Système Modèle : AlienWare (Dell) Aurora-R3 Numéro de Série : B2Z**** Chassis Système : AlienWare (Dell) Ordinateur de Bureau Carte mère : AlienWare (Dell) 046MHW Numéro de Série : ..CN6970********* BIOS Système : AlienWare (Dell) A06 05/25/2011 Mémoire Totale : 4Go DIMM DDR3 Processeurs Processeur : Intel(R) Core(TM) i5-2300 CPU @ 2.80GHz (4C 3.3GHz, 3.3GHz IMC, 2x 256ko L2, 6Mo L3) Prise/Connecteur : FC LGA1155 Chipset Contrôleur de Mémoire : Dell Core (Sandy Bridge) DRAM Controller 100MHz, 2x 2Go DIMM DDR3 1.33GHz 128-bit Module(s) de Mémoire Module de Mémoire : Samsung M378B5773DH0-CH9 2Go DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Module de Mémoire : Samsung M378B5773DH0-CH9 2Go DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Système Vidéo Moniteur : Dell Computer DELL U2211H (1920x1080, 21.7") Adaptateur Vidéo : NVIDIA GeForce GTX 460 (7CU 336SP SM5.0 1.3GHz, 512ko L2, 1Go 3.4GHz 256-bit, PCIe 2.00 x16) Processeurs Graphiques Processeur OpenCL : NVIDIA GeForce GTX 460 (336SP 7C 1.3GHz, 512ko L2, 1Go 3.4GHz 256-bit) Processeur Compute Shader : NVIDIA GeForce GTX 460 (336SP 7C 1.3GHz, 512ko L2, 1Go 3.4GHz 256-bit) Processeur CUDA : NVIDIA GeForce GTX 460 (336SP 7C 1.3GHz, 512ko L2, 1Go 3.4GHz 256-bit) Dispositifs de Stockage Physiques WDC WD5000AAKX-753CA1 (500.1Go, SATA600, 3.5", 7200rpm, 16Mo Cache) : 466Go (C:) Generic- SD/MMC (USB2) : N/A (E:) Generic- Compact Flash (USB2) : N/A (F:) Generic- SM/xD Picture (USB2) : N/A (G:) Generic- MS/MS-Pro (USB2) : N/A (H:) PLDS DVD+/-RW DH-24ABS (SATA150, DVD+-RW, CD-RW, 2Mo Cache) : N/A (D:) DTSOFT BDROM () : N/A (I:) Dispositifs de Stockage Logiques RECOVERY : 13Go (NTFS) Disque Dur (C:) : 453Go (NTFS) @ WDC WD5000AAKX-753CA1 (500.1Go, SATA600, 3.5", 7200rpm, 16Mo Cache) Lecteur Amovible (E:) : N/A @ Generic- SD/MMC (USB2) Lecteur Amovible (F:) : N/A @ Generic- Compact Flash (USB2) Lecteur Amovible (G:) : N/A @ Generic- SM/xD Picture (USB2) Lecteur Amovible (H:) : N/A @ Generic- MS/MS-Pro (USB2) CD-ROM/DVD (D:) : N/A @ PLDS DVD+/-RW DH-24ABS (SATA150, DVD+-RW, CD-RW, 2Mo Cache) CD-ROM/DVD (I:) : N/A @ DTSOFT BDROM () Périphériques Contrôleur Hub LPC 1 : Dell P67 LPC Controller Contrôleur Hérité LPC 1 : T0 10-05 Périphérique Audio : Dell Cougar Point High Definition Audio Controller Codec Audio : Realtek Semi High Definition Audio Périphérique Audio : nVidia GF104 High Definition Audio Controller Codec Audio : nVidia 0012 Codec Audio : 1 0001 Codec Audio : 1 0001 Contrôleur de Disque : Dell ICH8R (ICH8) SATA RAID Controller Contrôleur de Disque : Dell JMB362 AHCI Controller Contrôleur USB 1 : Dell Cougar Point USB Enhanced Host Controller #2 Contrôleur USB 2 : Dell Cougar Point USB Enhanced Host Controller #1 Contrôleur USB 3 : Dell Renesas Electronics USB 3.0 Host Controller Contrôleur FireWire/1394 1 : Dell VT6315 Series Firewire Controller Contrôleur SMBus Système 1 : Intel ICH SMBus Imprimantes et Fax Imprimante : Microsoft XPS Document Writer (600x600, Rendu des Couleurs) Fax : Microsoft Shared Fax Driver (200x200) Imprimante : Adobe PDF Converter (4000x4000, Rendu des Couleurs) Périphériques Services Réseau Adaptateur(s) Réseau(x) : Realtek PCIe GBE Family Controller (Ethernet) Adaptateur(s) Réseau(x) : Bigfoot Networks Killer Ethernet Controller (Ethernet, 100Mbps) Système(s) d'Exploitation Système Windows : Microsoft Windows 7 Personnel 6.01.7601 (Service Pack 1) Compatibilité de Plate-forme : x64 Indice de Performance Windows Système Actuel : 5.9
Initialization Error Code: -7 | dalecharlton | Windows | 10 | 09-29-2013 06:30 AM |
Code: -7 (Initialization Error) | JasonJN | Windows | 2 | 09-03-2013 04:02 PM |
What does Initialization Error Code: -7 do? | 6speedhemi | Windows | 2 | 04-05-2013 09:16 PM |
Initialization Error Code: -7 Help! | cmeier7 | Pro Tools M-Powered (Win) | 0 | 02-07-2013 10:58 PM |
Initialization error code: -7 | lubs7705 | Windows | 2 | 10-12-2012 08:49 PM |
