Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 09-08-2021, 09:17 AM
teacherman teacherman is offline
Default Switching from Cloud authorization to local iLok authorization ??
By default, when launching ProTools, Protools will automatically authorize via the Cloud.
During a session, if the Internet goes down, Protool will lose authorization and go off-line. Thus, the session stops: Protools will no longer function.
I have tried re-launching Protools with my iLok inserted in the computer. But, since my Protools is tied to the cloud for authorization, it does not seem to check my local iLok for authorization.
Question: Is there a way to tell Protools to check for local iLok authorization first before searching the cloud for authorization? Otherwise, if the Internet is down and I have no Internet service to login to my Avid account to change authorization settings, how can I force Protools to use the authorization on my iLok???
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 09-08-2021, 09:21 AM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Switching from Cloud authorization to local iLok authorization ??
If you have an iLok USB Key, and an available USB port, you might as well use that. You can move your license(s) to your iLok using iLok License Manager. If your iLok Cloud is set to Automatic mode... Close Your Cloud Session then activate the license(s) to your iLok. If it's set to Managed mode you can simply drag your license(s) from your iLok Cloud to your iLok USB Key. Check these out...
linkedin
Old 09-09-2021, 08:42 AM
My post has been moved. Where has it been moved to?
Old 09-09-2021, 10:07 AM
jeffro's Avatar
It's here. The topic of your thread was licensing so it was moved to the Licensing & Accounts subforum. When this is done a temp redirect is left in place. Sorry if this caused any concern!
linkedin
2nd Ilok authorization: best way to do? rjd2 Pro Tools 10 19 07-30-2014 08:51 AM
error: missing ilok authorization for pro tools... please insert the necessary ilok. Witold.B Pro Tools Express on Mac OS X 1 04-21-2014 03:59 AM
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. weakluv Windows 2 07-07-2011 05:47 PM
Authorization ilok Emanuele P. Virtual Instruments 5 08-02-2007 03:38 PM
ILOK Authorization!! basshead22 Pro Tools M-Powered (Mac) 8 10-28-2006 08:39 AM
