Old 07-31-2019, 12:18 PM
Mike Landolt Mike Landolt is offline
Default Option to add (2) Tablets to the S3 like the S1
It would be great to see Avid (or a third party) design a simple bracket that you could add/hold two tablets to the S3. And that it would implement the same features as the S1 will be offering with the new Protools-Control app.
Old 08-01-2019, 06:55 AM
sonichead sonichead is offline
Default Re: Option to add (2) Tablets to the S3 like the S1
I would love to see this as an option!!!
Old 08-01-2019, 09:09 AM
TrackerLe TrackerLe is offline
will never happen. the S3 is end of life....and will vanish, after the release of the S1, which brings features like up to 32 faders ...
The s3 is dead...sry
Old 08-01-2019, 08:10 PM
Just opinions here. I would not declare the S3 dead by a longshot. Also, since the multi-screen part of this is Eucon(which works even if the S3 is disconnected), I'd guess being able to use multiple iPads actually seems feasible to me(fingers crossed). In any case, we probably won't know for sure until the S1 and new Eucon are available for purchase
If it works, I can imagine fabricating a dual iPad holder out of a piece of 2x4(but then again, I have built all my own studio furniture and such for the past 16 years). Maybe I'll build a bunch and sell to S3 owners
Old 08-05-2019, 07:23 AM
MrDibS MrDibS is offline
First off, the S3 is absolutely not at end of life. The S1 and S3 are two different controllers. One does not preclude the other. Artist Mix is a different story.
Secondly, you can add as many tablets as you want to an S3. There is nothing proprietary about the S1 that allows it to pair with a tablet besides the bracket that holds it. The two operate completely separately but in tandem. You will be able to use that same tablet app with or without an S1 or S3 or anything else. It's just PT Control running on a tablet.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3.
Old 08-08-2019, 08:47 AM
Not that you won't be able to use multiple tablets with S3, but I'm not sure the above is entirely true. I had heard that the updated Control app will detect the surface being used, so that, with S1 it can act as a meter bridge and presumably bank channels along with the surface. I'm not sure if this functionality will be enabled with the S3, but it is certainly possible.
I am by no means certain of any of this, just going off what I remember from the articles and video surrounding the S1 and PT|Control app date announcement. We won't know for sure until it is released.
Scott Gatteρo
Old 08-08-2019, 09:45 AM
BScout BScout is offline
No need to guess. The product manager has already spoken on this forum and said “no” to the exact same questions. You will still be able to use Dock+Control app with S3. S1 will not be supported with the S3.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 12-26-2019, 08:31 PM
Undead Goat Undead Goat is offline
Has anyone tried this successfully already?
It looks like the avid control app can show 4 track meters when the tablet is set in portrait mode, or 8 track meters when set to landscape mode.
So if you want a display meter bridge, it looks like physically you would need either 2 or 4 tablets in order to line it up correctly. In this case, it looks like it will only be 2 because of the physical space constraints.
I'd like to better compare the functionality and features that distinguish an S1 from an S3. A handy display metering bridge that lines up with each track is one such feature I would like to know more about. Does it currently work that way with the S3 or nah
Old 12-26-2019, 11:24 PM
Southsidemusic's Avatar
The meter function only seem to work with the S1 and not the S3. I Hope I am wrong but we tried and couldn’t get that sweet metering function with our S3.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-29-2019, 08:53 PM
ramonetl ramonetl is offline
Each control app is bound specifically to a S1 unit in Eucon from what I am seeing with mine. You will literally see this unit in the same line as the S1 not separate as you would for the master control app with the dock. So one meter bridge per S1 is hard set as far as I can tell. They work as a unit. S3 folks need to just accept its not going to happen for them as a meter bridge and honestly for avid there is no need to rewrite to change that. it just is what it is.
Android Tablets for Dock? KeyplayerG Avid S1, S3, Dock and Control App 10 07-22-2019 07:50 PM
Waves V9 and Wacom Tablets @ndy General Discussion 2 04-01-2012 09:18 PM
tablets, anyone...????? bo-jingles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-11-2006 12:32 AM
Wacom tablets, What size? What other possibility? Ale Pro Tools TDM Systems (Mac) 0 08-14-2006 07:36 AM
Graphic Tablets? ear2ear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-28-2001 07:53 PM
