Old 05-08-2012, 12:39 AM
loginame loginame is offline
Default Protools 6.4 and Windows 7
I recently updated my pc from windows xp to windows 7. When I try to load PT 6.4 (Original Mbox) I keep getting messages about not having a DAE.dll file. I've researched this and discovered that PT 6.4 isn't compatible with windows 7 and updates have been discontinued. I therefore tried to load PT 6.4 through windows virtual pc - an application that creates a virtual windows xp system - but the same messages come up.
Is it at all possible to run PT 6.4 (Original Mbox) through windows 7 or windows virtual pc, or should I give up and buy new software/hardware altogether?
Thanks in advance.
Old 05-08-2012, 12:54 AM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Protools 6.4 and Windows 7
Win7 needs PT v8.04 or higher to run. The original Mbox is not supported by PT v8.03 or higher which by the sound of it you already know.
Looks like the windows virtual pc thing isn't working so I would be inclined to upgrade, or run the current version on an XP partition in a Dual Boot configuration so you have access to XP & Win7.
http://www.howtogeek.com/howto/8790/...puter-with-xp/
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 10-25-2014, 09:44 PM
supernova777 supernova777 is offline
i just read that someone was able to install 6.1.1 with an audiomediaIII card in windows 7.. the trick is that they used windows 7 32bit instead of 64bit
Old 10-25-2014, 11:01 PM
Forget Windows Virtual PC or any other hypervisor solution, they are unlikely to recognize audio interfaces and even if they did it would give poor/unreliable performance because of the CPU overhead, CPU and device IO latency that technology adds. Fantastic stuff for running non-audio/non-video legacy applications however.
You need to upgrade your hardware and software, or keep a dedicated PC running old Windows etc. for your DAW.
Windows ProTools 10 freezes at the click of "Install ProTools 10" JakeStrauss Windows 1 10-01-2012 08:53 PM
Protools 10.2 and Windows 8 HKnight Windows 11 09-09-2012 10:12 AM
Running Mac ProTools files on Windows ProTools DJ_Invisible_Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-16-2009 04:07 PM
convert Mac protools 7.0 to windows protools 6.4? Strainj1 Pro Tools TDM Systems (Win) 1 11-07-2006 10:42 AM
Will Protools 5.1 run on Windows XP pro? HELP!! Brian Maxwell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-27-2003 02:12 PM
