Please change Audio File Creator to ProTools!!!!!
Digidesign-Can you change the "File Creator" resource of Audio files recorded in ProTools?
As we all know, ProTools creates Sound Designer 2 Files. This is cool but the Creator App is still Sound Designer 2. I feel this should be changed to ProTools. Sound Designer 2 is no longer in development....this warrants the change IMO. It would be useful at times to be able to just double click on an Audio File created in ProTools and launch the ProTools App. Idealy this would launch the ProTools application, create a new session with the required tracks (stereo/mono file opens 2/1 track respectively) and display the audio file waveform (region) in these tracks and group the tracks if stereo interleaved. All other Audio Apps have their native files set to launch the application that created them. eg Peak creates nearly any audio file format (SD2,AIFF,.WAV etc) but the creator is always Peak-hence double click any of these files created/saved in Peak will open the files up in Peak. I really do feel this is long over due. Perhaps even Digidesign, you could create a new icon for this new file creator to distinguish it from normal Sound Designer 2 created files. Regards TaRGØN |
Re: Please change Audio File Creator to ProTools!!!!!
Hmmm...is that the reason why all the audio files recorded in ProTools have no icons (blank with the folded ear)?
Or is there any other reason why we've been unable to get the audio files with the little waveform icons. Have tried rebuilding the desktop, but it's still the same. |
With you on this.
A simpler template structure (perhaps a menu to choose from several when choosing a new file) would be nice.
Stuff, mostly |
Samhein,
Although not a real fix, you can use the freeware SDII Icon fixer, so your icons will have the little waveforms on them...I can't remember where I got it, but as it is freeware I will e-mail it to you if you like. |
Samhein,
If you want the icon, go to CoolstuffLabs and download iconfixer? it's a free tool that will give the icons that familiar sd2 look, or alternatively just keep an old copy of SD on your drive, you don't even need to authorize it for it to give its icon to your audio files. As for changing the creator, I'm not sure I want to launch ProTools just to listen to an audio file. An alternative is to use a control panel called DefaultApp. It lets you use any application to open any particular file. So you could have say Peak or SoundApp open your sd2 files when you double click them. jim |
Thanks guys!
Speaking of handy utilities, Playsound CMM is a contextual menu item which will play all sorts of sound files by control/clicking on them. Very handy, and only $5 shareware!
I used to boot MasterlistCD to audition SDII files ( much quicker then a PT boot) but this is even better. www.macdownload.com |
Another quick way to listen to files is to use the Mac's internal audio system, and play them using SoundApp. That way I can playback 16bit mixes while I have a 24bit mix in progress in ProTools. And SoundApp also does conversions, plays mp3s, etc.
Later, Brian Hear, Inc
Brian Steckler, Producer |
those are all helpful hints; I use playsound personally; but I still think Targon is on the money with his suggestion. how about it, Digi?
at least once a day I accidentally double click or command-O a sound file and then have to wait for SD2 to attempt to launch & tell me it can't find appropriate hardware. Paul Berolzheimer [email protected]
Paul Berolzheimer Sound recording & manipulation since 1980 [email protected] (818) 549-0622 |
The problem is, SD2 files are industry standard audio files, easily read by a variety of sound applications. If you change the file to a "ProTools" file, the files would no longer be compatible with these programs.
Change filename of an audio file from within PT? | sb_stefan | Pro Tools 10 | 4 | 04-19-2013 08:59 AM |
Change meter in an audio file | nikydvt | Windows | 3 | 01-02-2013 04:53 PM |
change sample rate info for audio file | djd2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-27-2007 05:19 PM |
What MP3 file type / creator settings do you use? | svenu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-07-2002 11:51 PM |
bounc to disc: MP3 file creator | Jeffrey Talbot | Pro Tools TDM Systems (Mac) | 1 | 03-13-2001 07:36 AM |
