Old 01-29-2012, 08:09 AM
john1192 john1192 is offline
Default HW device is different sample rate AVID
hello avid, HW device is at different rate from open session. Can we please address this ... causes ? solutions ?
my hardware and my session are at 96k ... i am running 32 bit floating point files to see how my system will run, what they sound, blah blah blah ...
i am getting this even after updating to 10.0.1 ...
thank you
john
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 01-29-2012, 07:29 PM
Default Re: HW device is different sample rate AVID
bump for a continuing issue
RME BabyFace Pro
RME BabyFace Pro
Old 01-30-2012, 02:57 PM
bump
RME BabyFace Pro
RME BabyFace Pro
Old 10-15-2013, 11:41 AM
Bvoss Bvoss is offline
I know this is well over a year old. I had this problem yesterday on my backup system. The computer somehow changed the hardware from my tascam box to pro tools aggregate. Once I changed that back in the playback engine, the session worked fine. Hope you figured it out .. nearly 2 years ago! :)
Pro tools could not set your audio device to the correct sample rate innermusic Pro Tools 10 4 05-06-2012 09:25 PM
Mytek + The HW device is at a different sample rate from the open session glynnp macOS 2 10-20-2011 03:53 PM
HW device is at a different sample rate from the open session bad jitter Pro Tools 9 2 08-16-2011 11:36 AM
New Avid MBox Sample Rate Problem vcirilli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-01-2011 05:26 AM
pro tools has reset the sample rate of the hw device because it was changed by anothe GHoSTFiNGeR Tips & Tricks 2 03-05-2010 10:13 AM
