Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 07-14-2019, 03:33 PM
gscaife gscaife is offline
Default Clarett 8 Pre Issues
I'm driving myself crazy trying to figure this out.
I submitted a trouble ticket to Focusrite a couple of days ago and have not heard back. I’m literally dead in the water until I can get this resolved.
Any source or instrument into the Clarett 8 Pre can be heard in the monitors and headphones out side of Pro Tools. When Pro Tools is running I can still hear the input source through the monitors and headphones - when I record arm the track I can hear the source twice, the original source and a slightly delayed duplicate. Nothing I have tried in FC seems to resolve this.
Here’s my setup:
Pro Tools 2019.6
Focusrite Control 3.2.1
Avid Artist Mix
Avid Dock
Focusrite Clarett 8 Pre
Focusrite OctpPre Mk II Dynamic
ART HeadAmp 6 Pro
MacBook Pro (Retina, 15-inch, mid 2015)
2.8 gHz Intel Core i7
16 GB 1600 MHz DDR3
macOS Mojave, 10.14.5
Any input will be greatly appreciated. Thanks!
Old 07-14-2019, 04:02 PM
Default Re: Clarett 8 Pre Issues
You have hardware monitoring enabled in the Clarrett 8. You need to read the appropriate Focusrite manual. What one are you using now?
Work out if your interface uses the old MixControl or the newer Focusrite Control. For a USB Pre I think it may be Mix Control. I would hope that info would be clear with whatever Focusrite supplied with your interface.
MixControl https://support.focusrite.com/hc/en-...Creating-Mixes
User Control https://d2zjg0qo565n2.cloudfront.net...user-guide.pdf
Nothing related to Pro Tools here.
Old 07-14-2019, 05:25 PM
Thanks for the response Darryl! The 8 Pre is Thunderbolt and I'm using the Focusrite Control User Guide. And, I can't find anything in the manual about enabling or disabling hardware monitoring.
Old 07-14-2019, 05:44 PM
Focusrite Control is *hardware monitoring* get rid of those signal paths, turn off whatever it is doing if you only want to monitor though Pro Tools.
Or even better with no Pro Tools running you should play with Focusrite Control until you understand how it works.
Old 07-14-2019, 06:33 PM
I've been using Pro Tools for years, my 003 died, and just got this Clarett 8 Pre, Artis Mix and Dock, and can't seem to wrap my brain around the FC as "middleware". But, thanks for the quick response. I'll get it figured out eventually.
Old 07-15-2019, 05:46 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is online now
It can take just a bit to get your head wrapped around it since it is kind of a "go between" for Pro Tools (or any DAW) so that you can monitor direct OR DAW monitor.
The manuals for the 8 Pre and Focusrite Control do a decent job explaining, but sometimes more is desired.
Look at the link for tutorials from Focusrite below. Hope that helps ya.
I love my Clarett 8Pre X.
https://support.focusrite.com/hc/en-...usrite-Control
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 07-15-2019, 02:52 PM
Thanks for the input Cowboy Bob!
I Found that if I turn OFF low latency monitoring in Pro Tools I can now here what's being sent to the track when I arm it for recording. I have the hardware inputs muted in FC.
So far so good. Except there are some latency problems now. Trying to work through that.
H/W Buffer size = 128 Samples
Any additional input will be much appreciated!
Old 07-15-2019, 08:33 PM
Turning off low-latency monitoring turn on Pro Tools software monitoring, that is all that does. So yes then naturally you can hear stuff via Pro Tools.
latency... you either run at a lower IO buffer or you use actually use hardware monitoring.
Focusrite Clarett 8 pre issues djendeavour77 Third Party Interfaces 10 03-31-2018 05:44 PM
Clarett pre 8 x jeam25 General Discussion 1 01-30-2018 07:10 AM
Focusrite Clarett 2Pre/Clarett Octopre w/PT11 shultzee13 Pro Tools 11 0 03-24-2017 08:08 PM
Focusrite Clarett 8 Pre X Cowboy Bob Third Party Interfaces 31 03-12-2016 04:41 PM
