Help us help you
Hi guys,
We are having trouble reproducing issues in our test studio. I've put together some questions to help us isolate issues. If you can help us by answering these questions we can get to a reproduction and resolution. http://www.surveymonkey.com/s/R6KM2GZ |
Re: Help us help you
IMPORTANT!
We are trying to track down a specific issue related to the EUCON 3.0 release for Artist Series. Please only respond to this survey if you are seeing the following issue: - Pro Tools 11 fails to connect/populate the Artist Surfaces. Surfaces do connect to EuControl. This issue is described in the following thread(s): http://duc.avid.com/showthread.php?t=341036 http://duc.avid.com/showthread.php?t=340362 |
Not working for me on either pt 10.3.6, pt 11 or pt 11 HD. On windows 7 Ultimate.
PM sent
Worked for me (so far):
1. Uninstalled version 2.7.1 2. Installed version 3.0. 3. Both PT 10 and 11 started fine with my artist gear (2 x Mix, Control and Transport). 4. Turned Mac off. Waited a minute. Turned Mac on. 5. Both PT 10 and 11 DID NOT start with my artist gear. 6. On EUCON Preferences: Clicked "Stop". Waited 30 sec, and clicked "Start". 7. Both PT 10 and 11 started fine with my artist gear. 8. Turned Mac off. Waited a minute. Turned Mac on. 9. Both PT 10 and 11 started fine with my artist gear. |
I have the same issue, but I have to stop-start every time that I start the Mac.
We have some additional questions, some of these may seem redundant or simplistic however they will clue is in to the root issue that is causing the startup failure.
1. After rebooting and before starting ProTools, or any other DAW, is the MC_Client application running on your system? - Use spotlight to open Activity Monitor. Search for "MC_Client". - If not there make sure the drop down next to the search box is set to "All Processes" before answering "no"). 2. Is EUCON configured to start automatically on system boot? - Go to System Preferences, EUCON. There's a button next to the "Delete" button, does it say "Start" or "Stop"? (NOTE: Start means that EUCON does NOT start automatically, Stop means it DOES start automatically) 3. Do you launch EuControl manually after a reboot? - If yes to 3., do you start it before or after launching ProTools? Sent from my iPhone using Tapatalk 2 |
[QUOTE=DanielEUCON;2066077]We have some additional questions, some of these may seem redundant or simplistic however they will clue is in to the root issue that is causing the startup failure.
1. After rebooting and before starting ProTools, or any other DAW, is the MC_Client application running on your system? - Use spotlight to open Activity Monitor. Search for "MC_Client". - If not there make sure the drop down next to the search box is set to "All Processes" before answering "no"). Yes it's running. 2. Is EUCON configured to start automatically on system boot? - Go to System Preferences, EUCON. There's a button next to the "Delete" button, does it say "Start" or "Stop"? (NOTE: Start means that EUCON does NOT start automatically, Stop means it DOES start automatically) It says stop. 3. Do you launch EuControl manually after a reboot? - If yes to 3., do you start it before or after launching ProTools? I have to stop and re-start the service to get it to work, then run Pro Tools. Hope this helps, Jerry Woolsey. |
[QUOTE=Jerry Woolsey;2066502]
exact same issue here.
My System Mac mini M1 OS X 11.6.4 PreSonus 1824c Faderport 16 Pro Tools Ultimate 2021.12 Studio One 6.5 Pro Logic Pro X |
Same here.
OS 10.8.4 PT HDN 10.3.7 PT HDN 11.0.2 |
