Issue with Track Color in Edit Window
Hi all,
We have been experiencing a eird bug in PT9HD recently which is really hampering the workflow in the studio. For some reason the track color part of each track in the edit window is remaining black, regardless of the actual track color. (We have checked coloring regions and tracks independently and have verified that the track is in fact colored, ie: new regions are not blue f.ex) Has anyone come across this issue before and does anyone know what may be done about it? All the very best, Robin |
Re: Issue with Track Color in Edit Window
Check the saturation level slider, and can't remember but there may also be a button to turn colr off next to the slider...?
Lincoln Mitchell Pro Tools | latest Mac Mini Server | OSX | Current 16GB Ram | SSHD Apogee Ensemble Thunderbolt |
Hi, thanks for replying.
We've tried all the regular options. I dont think this is a preference issue, more a bug and am wondering if anyone else has come across it? |
I was having the same exact problem, it seems to be triggered when you open a session from older PT versions.
Solution: In your VIEW MENU go to EDIT WINDOW VIEWS - and check TRACK COLOR. Done... |
LAStudio your solution has saved the day!
Believe it or not this bug still exists in pro tools 12.5, and your solution still works. Thank you!
Mac Pro Cylinder 2013, Mavericks 10.9.4, 10 Core Intel Xeon E5 3.0 GHZ, 256GB Hard Drive, 32GB Ram Pro Tools HD 11.2.1 HD Native PCIe and and UAD-2 Octo PCIe in Magma ExpressBox 3T HD I/O 16x16 Analog UAD Software 7.10 6GB Lacie 2Big Thunderbolt drive for Audio (set up in JBOD mode) |
Go to the track and at the top is the little window with an arrow-the same you use for track size...scroll down to the bottom and you will see Track Color, click on that. Also in the color window to the left of the saturation slider is a button with red, white and blue, enable that, and of course use the saturation and brightness sliders to adjust the color. The Clips In Tracks button, located in the color window also allows you to choose what portion of the track you want hi-lighted. Make sure you click on the track you want the color for as well.
Mac Book Pro 2.93GHz Intel Core 2 Duo 4GB 1067MHz DDR 3 Digi 003 Rack, ProTools 8.0.5 |
Not sure i'd call it a bug, but it does seem silly that anyone would need the option to show color in 1 window but not the other Took me a year before I finally found that option
Because when editing audio all day, black waveforms is actually easier on the eyes and brain. You can still keep colors on the mixer window to organize tracks.
Weird track color issue with groups | Thumper1040 | Pro Tools TDM Systems (Mac) | 6 | 10-07-2011 07:20 AM |
8.01 and Edit Window/Color Question | acmost | Pro Tools TDM Systems (Mac) | 5 | 10-11-2009 11:25 AM |
How do I get color back in edit window? | jjboogie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-31-2009 11:11 AM |
PT 7.3 MIX WINDOW TRACK COLOR | AMIEL | Pro Tools TDM Systems (Mac) | 7 | 05-28-2007 08:00 AM |
Color coding regions in Edit window? | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2001 01:37 PM |
