Old 06-25-2015, 11:58 AM
dunebuggy dunebuggy is offline
Default Mapping to custom faders
Hi,Have a blank, did it a while ago.
How to I get to map plugin parameters on custom faders on a Dcommand.
I remembered a combination of keys was making the blue light to blink and then I just had to tap the desired fader to assign, it's a bit of a blur and I m having no luck with the forum search function.
Thanks in advance
Eric
Old 06-25-2015, 01:37 PM
Drew Mazurek's Avatar
Default Re: Mapping to custom faders
Thanks in advance
Eric
Enter custom fader plugin mode, press map, select fader, touch control to assign.
www.drewmazurek.com
Old 06-29-2015, 08:16 AM
Thanks for the reply Drew ,
But it still not working, i m trying to map Izotope rx4 dial denoise, i m OK for a custom mapping on the rotary but still jammed for a 8 faders control….
Eric
Old 06-29-2015, 08:24 AM
Eric
I only have RX3 here, but the DeNoise module maps perfectly to the faders just as I described. Must be 4 specific. I'd contact Izotope, might be a bug.
www.drewmazurek.com
Old 06-29-2015, 08:51 AM
I ll check that , thanks !
Custom Plugin Mapping with Nuendo? J-S-Q Artist Series 2 04-23-2015 03:02 AM
AX49 PTM8 faders mapping zguit MIDI 1 12-21-2010 06:18 AM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 06:44 PM
Request for Custom Surround Mapping mavericksound Post - Surround - Video 2 04-22-2007 09:51 AM
Have you guys been using custom faders? Igotsoul4u ICON & C|24 5 12-22-2004 05:23 AM
