Old 06-19-2007, 10:26 AM
Tim R. Tim R. is offline
Default Negative \"User offset\" ADC numbers possible?
On Apogee's website it says that Digi doesn't support negative compensation (and that the only way to compensate negatively is to nudge), but in the PT's manual it states that you CAN enter a negative number in the User offset. I've found though, that entering a negative number does NOTHING to compensate.
Anyone know what the deal is with negative user offset numbers?
I'm trying to compensate for the Rosetta 800's analog I/O delay (which I've found to be 63 samples in my case).
Tim
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 06-19-2007, 03:14 PM
Stig Eliassen's Avatar
Default Re: Negative \"User offset\" ADC numbers possible?
If you've made the Rosetta an insert in the I/O setup, you can type in a H/W insert delay. I believe you must use milliseconds, so it's 63 samples/ 44.1 ~ 1.43 ms of delay.
I don't think the session sample rate affects the delay of external devices, but I almost blew a fuse in my brain thinking about it.
Delay Compensation, User offset negative HiLoc Pro Tools TDM Systems (Mac) 4 04-03-2010 01:18 AM
Negative Video Sync Offset??? admix Post - Surround - Video 3 05-15-2008 10:34 AM
Negative Measure Numbers? Like -1, 0, 1 smc917 Pro Tools TDM Systems (Mac) 2 02-11-2007 06:30 PM
negative feet.frames offset? is it even possible? sndgeek Post - Surround - Video 7 06-20-2004 11:27 PM
Negative Clock Numbers...? Zetajazz44 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-01-2004 10:29 AM
