Old 06-28-2011, 03:18 PM
Stig Eliassen's Avatar
Default PT 9 HD & VE Pro - happy?
I'm seeking some insight from users that does it all on a single machine. In short - are you satisfied?
Thank you.
Old 06-29-2011, 12:03 AM
WarrenG WarrenG is offline
Default Re: PT 9 HD & VE Pro - happy?
Thank you.
Yes, all works fine for me. Never had a problem!
Best regards
Warren
Website
FaceBook
MySpace
Old 06-29-2011, 12:18 AM
Marsdy Marsdy is offline
Works great here too. VERY stable. Just keep PT memory usage below 2.5 GB.
http://duc.avid.com/showthread.php?t=283623
Dave Marsden
UK
Old 06-29-2011, 02:47 AM
Thanks, guys. Are you in 32-bit mode?
Old 06-29-2011, 09:22 AM
I was in using VE Pro in 32 bit mode for a year. It worked great and never crashed once in all that time with very heavy use!
Unfortunately I built a new template and hit the memory limit for VE Pro in 32 bit mode so I've been in 64 bit mode for two months. Downside is I now have to have the Kontakt Memory Server turned off so I can't load as much in PT anymore.
Incidentally, I found the VE Pro 32 bit memory limit to be around 2.5 GB. Same as PT and Logic in 32 bit.
Dave Marsden
UK
Old 06-29-2011, 02:02 PM
I see. Doesn't Kontakt work for you in VEP?
Old 06-29-2011, 02:11 PM
DarylG DarylG is offline
Exactly. No need for a memory server.
D
ProTools 9.02
2 x Intel Xeon x5675 3.07GHz Hex Core
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
ATI HD5400 series graphics card
Old 06-29-2011, 04:10 PM
It works extremely well in either the 64 or 32 bit version of VE Pro. I have well over 20 Kontakt instances running all the time and it's rock solid.
The issue is, if you're running Kontakt 64 bit in VE Pro, you need to turn KMS off. If you also load instances of Kontakt in PT like I often do, it will eat into PT's precious memory allocation very quickly.
Sometimes it's nice to quickly load something in PT without disturbing the main VI template I have running in VE Pro if that makes sense!?
Dave Marsden
UK
Old 06-29-2011, 04:26 PM
But, how is that a problem? I mean, isn't KMS only helpful in 32-bit mode, and doesn't the added memory access in 64-bit remove the need for KMS?
Yeah, that makes total sense. I'm starting to become pretty anal about these things myself.
Old 06-29-2011, 05:00 PM
Stig
If you load an instance of Kontakt in PT it is running in 32 bit mode. Obviously it would be nice to have KMS on so as not to eat up PT's memory allocation!!
However if you ALSO want to run Kontakt in the 64 bit version of VE Pro on the same Mac, then KSM has to be off.
There's a bit of a compromise in other words. Either run VE Pro in 32 bit mode and possibly hit VE Pro's 2.5 GB limit, or run VE Pro 64 bit and possibly hit PT's 2.5 GB limit if you load too many instances of Kontakts in PT.
If you can do everything in VE Pro then there isn't an issue. However, like I said, it's sometimes really handy just to quickly load something in PT rather than futz about loading stuff in VE Pro and patching it through to PT.
Dave Marsden
UK
not happy djcalg Virtual Instruments 4 03-27-2010 06:50 PM
Happy T-Day bluedemon General Discussion 0 11-24-2004 04:09 PM
So, everybody is happy w/ 6.7 LE? Tubz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-22-2004 05:58 PM
Are you Happy with Your 002?? AudioOIART 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-09-2004 06:09 AM
Considering C24. Are you happy? Rams Boy ICON & C|24 6 11-27-2001 09:51 PM
