Old 12-22-2010, 07:41 PM
Logic 9 Logic 9 is offline
Default How to determine RMS and PEAK in PT ?
I was wondering, how can I see dBFS peaks on individual channel strip meters of ProTools ? I can just see meter jumping up and down but I can't see any displayed levels of my audio and MIDI (aside from fader position level).
Is there any way to make that happen ? And if no, how do you guys determine what are yours RMS and Peak levels at any given track ?
Thanks a lot in advance.
Old 12-23-2010, 01:45 PM
Default Re: How to determine RMS and PEAK in PT ?
So there is no way to get meters in real time in ProTools ...
Old 12-23-2010, 02:54 PM
HD2 HD2 is offline
If you mean you want to see numbers then go up to view and makes sure "narrow mix" is unchecked. Or hit option + apple + M
Old 12-23-2010, 03:41 PM
Slim Shady Slim Shady is offline
Command-click on the volume indicator display to toggle between volume, peak and delay.
You can also go into Preferences under Display and change peak hold to infinite.
Old 12-24-2010, 03:59 AM
HD2 Thanks man.
Slim Shady...Awesome. That's exactly what I was looking for.
Thanks a lot guys.
Old 12-24-2010, 06:12 AM
Alécio Costa's Avatar
Alécio Costa Alécio Costa is offline
If you want to see RMS you may insert the Phase Scope Plug-in from Avid Digirack suite.
Alécio Costa Studio
High-End e-Mastering & Music Production
www.aleciocosta.com
http://www.facebook.com/alecio.costa
PT Ultimate Native 2023.3 - Mac Mini M1 16GB RAM - Mac Os Ventura 13.2 - 2 192 IO Digidesign Digital
PT HD2 Accel - 10.3.10 OS 10.6.8 - Mac Pro 2008 16GB RAM
Mastering Gear: Pendulum Audio, Crane Song, Avalon, Great River, Sebatron, Sonnox, Izotope, PSP, TC, Fab Filter.
Old 07-30-2011, 06:22 AM
Silvio Silvio is offline
But then what kind of volume the Protools meter shows? Not RMS?
And, another question, what's the measured value of the LEQ (A) in phasescope? RMS?
I'm lost :S
Old 07-30-2011, 07:26 AM
Post Re: How to determine RMS and PEAK in PT ?
Peak.
Not RMS?
Correct.
Old 07-30-2011, 07:46 AM
Originally Posted by Chief Technician View Post
Peak.
Correct.
Thank you so much, I've been searching for this for a long time.
So, if I want to check for RMs volume on a track, I can use the Phasescope plugin with the meter set to RMS, right? But then, even if RMS is supposed to be an average volume, the meter in the phasescope can vary about 5db up and down on a constant dynamic part of a track. What value should I consider as the "RMS value" of a constant part of a track: the top one or the low one? Or the middle one?
My main concern is I want to record sources around -18dbfs RMS to leave headroom for the plugin process. And I'd like a good way to measure this with precision.
Thanks again, you're really helping me.
Old 07-30-2011, 02:59 PM
elicious elicious is offline
free...
not real time, but great for checking pre-and-post mastering.
the most configurable tool out there is spectra foo.
another really good one is the metering section from slate's fgx.
those will do what you're asking.
b.o.l.
e
ihatetyping
Determine Meter? imresults macOS 1 02-12-2013 02:17 PM
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
Couldn't determine 4CC ID! bedermanbeder Pro Tools M-Powered (Win) 0 07-16-2010 06:26 PM
Mbox Peak / Peak Light Issue soulcatcher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-29-2004 08:01 PM
