Advantage of More DSP's for Same Voice Count?
The Pro-Tools reference guide, offers a chart, for different HD systems Voice capabilities at different samplerates, but does not elaborate on what the advantages of using 3 DSP's for 96 voices, over 2 DSP's for 96 voices, or 1 v.s. 3 DSP's for 48 voices ect.
Can someone explain the advantages of allocating a higher number of DSP's for a voice count, when a setting is available, to have the same amount of voices, with less DSP. T.I.A |
Re: Advantage of More DSP's for Same Voice Count?
There's no Real advantage as such, Run on the lowest! if you start to get DAE error messages then you might need to allocate more DSP for voices. Chris
I seemed to remember that there was an issue with PCI bus overloads if you used more Chips but it might be the other way around. In general I have always aimed for less DSP for more voices so I have more chips for Plug-ins.
my 2c Simon L. |
I previously had an issue with noisy plugins and fuzzy distorted noises (when doing complex mixes using lots of horsepower), which was cured by upping the DSP chip number.
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc. |
HD7 voice count | Raoul23 | Pro Tools TDM Systems (Win) | 7 | 11-13-2011 01:08 AM |
PT HD voice count | garnoil | Pro Tools TDM Systems (Mac) | 10 | 11-05-2008 07:47 PM |
Advantage of 16 voice 2 dsp over 16 voice 1 dsp? | flymax | Pro Tools TDM Systems (Mac) | 4 | 02-04-2006 01:10 PM |
96 voice 2 dsp's, 3 dsp's or 6 dsp's question | crizdee | Pro Tools TDM Systems (Mac) | 1 | 05-17-2005 04:55 PM |
Voice count for PT NT|24 Mix | Euphony Sound | Pro Tools TDM Systems (Win) | 1 | 04-21-1999 10:26 AM |
