Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 12-02-2019, 07:18 AM
Protone Protone is offline
Default Drawing volume automation for VCA grouped tracks
I am new to using VCA groups, and I have some trouble figuring it out. I have a group of tracks that are all in the same VCA group, controlled by VCA master track.
Now, if I try to draw volume automation (on screen, using mouse) to one of the grouped tracks, the edits happen to all tracks in the group. No matter what setting I have in "modify group" settings.
How ever, if I record volume automation by moving a fader, it only automates the selected track as it should.
I like to do some automation edits by mouse, so is there a way to edit single track volume automation like that while the track is part of VCA group?
Thanks
Old 12-02-2019, 08:06 AM
amagras amagras is offline
Default Re: Drawing volume automation for VCA grouped tracks
You just have to bypass all groups before drawing the automation, i think is alt+shift+g
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 12-02-2019, 09:31 AM
Thanks!
Yeah, bypassing the group seems to solve this. I was hoping I was just missing some setting, because bypassing and re-activating groups all the time is not optimal.
VCA master seems to work even when the group is bypassed though. Is this a bug, or is this how it is supposed to work? Maybe I can keep the groups bypassed all the time then..
Old 12-03-2019, 08:45 AM
reichman's Avatar
reichman reichman is offline
That is by design. The VCA will always operate, regardless of the status of the mix group. I recommend simply unhighlighting the VCA groups, that way your other groups and your 'suspend all groups' command can be useful in other ways.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Changing volume of grouped tracks bjoern268 macOS 6 02-03-2019 03:28 PM
How To? Grouped tracks to follow automation lane sections tooold macOS 3 06-29-2017 06:42 AM
drawing volume Automation...... Jperkins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2005 11:03 AM
Can't I edit plug-in automation data simultaneously on grouped tracks (identical plu? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-02-2002 12:57 AM
How do I trim (NOT shift) plug-in automation data on grouped tracks? el biciclista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-01-2002 08:34 PM
