Pro Tools 8 stereo recording
I'm recording some old DAT tapes into ProTools using an MBox 2. My set up is an SPDIF from the DAT machine into the MBox, which of course is a stereo input. I've started recording on a stereo channel in Pro Tools 8 but the problem is the audio files are saving on my hard drive as a separate left & right channel. Is there any way I can get the audio files to save as 1 stereo track on my hard drive? Thanks |
Re: Pro Tools 8 stereo recording
Pro Tools 9 and older always record separate tracks for stereo signals(PT10 has the option of interleaved). If you select a stereo track in a session and go to the Regions bin(Clips bin for 10 users) and choose Export Regions as Files, you can select to export as an interleaved file. Or you can Bounce to Disk, and select Interleaved(both net the same result, but the Export function is faster). If this doesn't help, tell us exactly why its important(why it matters) and maybe someone will have a better solution
Thanks for the reply.
We're a production house who do Radio shows. In have thousands of shows on DAT tapes going back more than 10 years and i wanted to transfer them all to hard drives. So i'm recording each tape into pro tools, but i want to avoid any editing or bouncing back as that will take too much time. I was hoping to just record each tape into Pro Tools 8, and then the audio file which it saves will already be stereo so i don't have to do anything additional once the tape has finished recording. Because of the quantity of tapes it's already a project that's going to take years to complete. Thanks for your help. |
In this case, use the Export Regions as Files method and you should be all set.(its the fastest method anyway).
To recap for the curious: record the DAT to a stereo audio track. Trim if needed. Normalize if you like(with the AudioSuite Normalize plugin). Select the region so its highlighted in the Regions bin, Option-click and select Export Regions as Files, select the sample rate and bit depth, interleaved, pick the destination and let 'er rip. Pretty fast and very simple
AMAZING!!! Thank you very much, it worked brilliantly!!
Stereo recording | sjan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-29-2007 06:55 AM |
Pro tools Stereo Recording | Thundakat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2007 12:50 PM |
Stereo Recording | axetjb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-13-2006 08:18 PM |
Recording in Stereo please help! | Darkhand | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-20-2004 07:44 AM |
using 2 different pre for stereo recording | rems | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2003 11:14 AM |
