Old 09-26-2008, 10:03 AM
jeffpardo jeffpardo is offline
Default Re: Blinking STOP/PLAY transport buttons PLAYBACK ISSUE
Just registered here on the forum....I'm having this same issue as well....I mostly notice it when creating new sessions, not so much when opening existing sessions.
Anybody else having this issue? Any fix on the way, Mr Digi?
Old 09-29-2008, 09:17 AM
DigiTechSupt's Avatar
Knowing more about your system would help a lot. See the Help Us Help You thread...
Most of these play/stop issues have been fixed in recent CS releases for Pro Tools. If you continue to experience problems, it's most likely due to having incompatible plug-ins installed, you're engaging a particular mode, you have a very short selection and don't realize it or there are other configuration issues that would need to be sorted out.
Avid Audio Tech Support
Support FAQ
Old 10-01-2008, 01:31 PM
3ngin33r 3ngin33r is offline
Hey people,
Unfortunately, this issue is a longstanding one. Much of what I've read on the forum about this particular anomaly is consistent with what I would certainly call a "bug", especially considering it occurs cross-platform with an incredible variety of hardware/3rd-party software implementation. There are posts dating back 4-5 years about this and as far as I know it hasn't been fixed.
It's been happening to me intermittently for years...for me, it's usually brought on by a period of inactivity...taking some sort of break for an inordinate amount of time. I thought that was it...usually a quit/restart of PT does the trick...you can't just close/re-open the session.
However, the fact that it still happens at all is absolutely effing ridiculous. It's program-related for sure. It used to happen to me even BEFORE I had installed any 3rd-party plugs OR any Digi software bundled with PT, so I don't want to hear it.
I've been running PTLE on a G5 for years with Avastor HDX drives. I've used other drives and it happened then too. All this switching parameters and settings and preferences and resetting junk is putting a Band-Aid on a laceration that obviously needs a few stitches. I mean, SO WHAT I can turn it off and turn it back on again and it MIGHT work for a bit before it happens again...but everyone KNOWS that no one should HAVE TO.
Fix it already, and show us that you REALLY care Digi.
Thnx.
Old 10-02-2008, 04:03 PM
As I mentioned above, 7.4 and certain recent CS releases for 7.4 should have addressed a majority of any play/stop issues. There was only one that exhibited itself in our testing (and even that was much less frequently) - if you leave your computer on and Pro Tools session open for extended periods (like more than 4-6 hours). All others seemed to be fixed or reduced greatly in frequency.
Support FAQ
Old 12-03-2008, 05:35 PM
Reesho Reesho is offline
PT LE 7.4.2 on a Mac Pro 8 core OSX 10.5.4
I leave the computer inactive for a few hours with a PT session open and yes there it is - the non-functional blinking play button. It's as if PT over an extended period of inactivity loses touch with the hardware or something. Anyway a reboot of PT gets it working again. Having said that I have to agree that rebooting should not be necessary so I guess we still don't have an ideal world. But we're workin' on it right Digi?
Mac Pro 2x3.46 Ghz Dual 6-Core Intel Xeon
64 GB Ram
OSX High Sierra 10.13.6
PTLE Subscription - pending
Interface - pending
Midi Controller =M-Audio Axiom 49/USB2
  #16
Old 12-05-2008, 01:11 PM
abdallah_harati abdallah_harati is offline
Originally Posted by guitarman6 View Post
Checked H/W buffer and changed to 1024 samples. RTAS Processors running = 2, CPU Usage Limit = 90%, DAE Playback Buffer = 8. Still have the same problem when I set all that and try to playback from the session. Blinking STOP button and then 3 blinks from PLAY button (looks like its trying to sync to something but I have no idea what since I have nothing selected to sync).
Perfect! It worked here and solved the problem. I noticed it happens more with MIDI. I never experienced it with pure audio recording before.
Thanks for helping!
  #17
Old 12-05-2008, 02:32 PM
altavek altavek is offline
We run into this problem constantly and it's crazy-making. There's some common key command that is standard in every other app except in PT, and it activates either the Metronome or the Tempo Ruler enable, resulting in flashing transport buttons.
Conclusion: check your transport using expanded view w/ MIDI controls and disable Metronome and Tempo Ruler.
  #18
Old 12-12-2009, 09:00 AM
skilletaudio skilletaudio is offline
Originally Posted by Earthling View Post
for now I just disable the 2nd processor.
Changing the processor used to something else and then back to the previous setting fixed it for me without restarting.
  #19
Old 07-05-2011, 06:19 PM
mushoo mushoo is offline
Exclamation Re: Blinking STOP/PLAY transport buttons PLAYBACK ISSUE
Reviving a dead thread - I've got this, or something VERY similar, happening in PT 9.0.3. (Haven't tried 9.0.4 yet).
It's more consistent, now, and has a workaround, but still frustrating. Basically, whenever I do a bounce to disk (to mp3, specifically) on certain sessions, afterwards I get the play/stop flash behavior - only the buttons don't actually flash. I hit play, PT thinks, then stops. The 'fix' is to open the Playback Engine dialog, switch the hardware buffer to something else, then switch it back, then close the PB Engine window.
The workaround 'works' most of the time but it's still very frustrating.
PT 9.0.3, Complete Toolkit, OSX 10.6.6, Mac Pro 8 Core 3ghz, 5gb RAM. Current plugins in the session: Reaktor, Massive, Omnisphere, Maschine, Decapitator, McDSP ML4000. Using Pro Tools Aggregate IO.
  #20
Old 07-06-2011, 05:00 AM
The golfer The golfer is offline
I have this problem once in a while. Hitting the "alt option" key resumes normal operation.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
C24 all transport buttons led on (play,FF,Rew,,Stop and talk back Ze Fortes ICON & C|24 2 09-26-2012 12:25 PM
Playback issue - Solid Stop/Flashing Play systemcell macOS 5 08-10-2011 01:41 AM
When press play the stop key lite and play key blinking Sam Yin Tips & Tricks 6 12-05-2009 08:26 PM
Play and Stop Buttons both flashing - track window froze Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-08-2008 01:13 PM
Transport Play Lit, but no playback slimfass27 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-17-2005 04:57 PM
