When I enable a track to record and then hit 'play' the track will remain silent
Unfortunately I've got 2 keyboards plugged in, one was left on the ground and I accidentally got a bit happy with my feet and well - I think I triggered a few unnecessary shortcut keys! Basically my problem is that when I set a track to record (by clicking on the R and making it red), then if I hit play, that track will remain silent whilst the rest of the song plays. This is driving me mad. Obviously I expect to be able to hear the track unless I hit record + play and lay down a recording. Its more annoying when I want to record over a small section so obviously I need to hear the part of the track through my headphones before I reach the punch into the section I'm recording into. Basically what I want is it to go back to how it normally was, you set a track on record, and if you decide to play your session that track will play what is currently recorded and the live sound through the track (eg guitar plugged in) is muted. I hope this makes sense and it's easily fixable. I'm running pro tools m-powered 7.4 on a PC Cheers William Thanks for your time! |
Re: When I enable a track to record and then hit 'play' the track will remain silent
alt+k
yes you want to swap input only mode/auto input monitoring
track record enable static | joshprotoologic | Pro Tools 9 | 3 | 10-15-2012 08:36 AM |
can't record enable a track | macfreak86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2011 05:11 PM |
Track Record Enable KC | mattrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-26-2009 06:58 AM |
Why can I only record enable/play one midi track at a time? | Martin Dubka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2008 01:24 PM |
Can't record enable track in DP 3 | clockface | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-29-2003 11:05 AM |
