Old 10-16-2007, 05:50 AM
dekype dekype is offline
Default Hardware for Pro Tools LE 6.7
I have PT LE 6.7 Installed on my lap top.
Lap top has USB only.
What hardware is required to use it?
thanks
Old 10-16-2007, 07:18 AM
spkguitar's Avatar
Default Re: Hardware for Pro Tools LE 6.7
Ummmm.
Pro Tools usually doesn't come without the hardware required to run it. I'm not sure how you could have installed Pro Tools 6.7 without first purchasing the hardware. If you could explain that, we would definitely be able to help you better.
Pro Tools 6.7 is also an old version of Pro Tools. (actually, very old at this point). It would be limited to and compatible with the following hardware only;
  • Digidesign 002 (firewire)
  • Digidesign 002R (firewire)
  • mBox (the original one only; USB)
So, as you can see, if you don't have a firewire connection, and you aren't willing to purchase a PCMCIA firewire card, your only option for 6.7 is the original mbox. If you, for some strange reason, have the software and not the hardware, you are going to have to purchase the hardware which will come with a version of the software anyway, and if you are going to buy hardware that comes with the software, you might as well buy one of the newer hardware units that comes with the newer versions of the software and not limit yourself.
Just having the software does you no good at all.
Old 10-16-2007, 08:13 AM
Camilo Toledo Camilo Toledo is offline
You may be able to get Protools software, but as explained above, and to put it in concrete words, you actually need to make a real purchase and get the software which comes with its propietary hardware.
For around $300 you can get an Mbox mini USB, wich comes with "basically" everything you could probably need to start recording.
Camilo Toledo
How do I get Pro Tools 9 to run w/o hardware Ms.Samo Windows 14 04-21-2011 06:35 PM
Pro Tools 9 and Mix Hardware RFMProductions Pro Tools 9 0 11-12-2010 03:09 PM
Hardware EQ vs Pro Tools fatone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-13-2004 06:34 AM
Do you need Pro Tools Hardware to run LE protram 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-19-2002 11:21 PM
Pro Tools Hardware gist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-20-2001 12:32 AM
