USB Audio Device is not compatible with this version of Windows (Vista Laptop).
Has anyone got this Microsoft system message on boot up? Do I use only firewire?
After doing some updates I get this message on Microsoft OS bootup: "Address a problem with USB Audio Device USB Audio Device is not compatible with this version of Windows. Digidesign, the company that manufactured USB Audio Device, has informed Microsoft that they don't expect to offer updates to solve this problem. To search for similar devices that are compatible with Windows Vista, go online to the Windows Vista Compatibility Center: " |
Re: USB Audio Device is not compatible with this version of Windows (Vista Laptop).
Has this message been problem? Has it stopped you from installing or running PT? or is it just a warning message?
- but the second mouse gets the cheese |
Durring instalation Digi tells you to ignore Window's prompts and allow Digi to install the drivers.
I have not been able to get PT LE to run. I was hoping that the audio USB from Digidesign will work on my vista ultimate laptop. thanks...
Which Pro Tools interface???
Here is my config for my laptop. I have the PT Mbox 2 Mini. I was just hoping to get the program to run somehow, maybe with a modification if needed...thanks.
Computer Model : Dell Inspiron 1525 Processor Model : Intel(R) Core(TM)2 Duo CPU T7250 @ 2.00GHz Speed : 2.2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Dell 0WP007 BIOS : Dell A17 10/27/2009 Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DDR2 SO-DIMM Chipset Model : Dell Mobile PM965/GM965/GL960 Express Processor to DRAM Controller Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 4GB DDR2 SO-DIMM Shared Memory : 8MB Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module : Samsung M4 70T5663CZ3-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M4 70T5663CZ3-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : Mobile Intel(R) 965 Express Chipset Family (8 SP, Integrated Graphics) Graphics Processor Storage Devices TOSHIBA MK2546GSX (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) (D:) TSSTcorp DVD+/-RW TS-L632H (ATA33, DVD+-RW, CD-RW, 2MB Cache) : 4GB (E:) Logical Storage Devices RECOVERY (D:) : 10GB (NTFS) @ TOSHIBA MK2546GSX (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) OS (C:) : 162GB (NTFS) @ TOSHIBA MK2546GSX (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Pro Tools LE (E:) : 4GB (CDFS) @ TSSTcorp DVD+/-RW TS-L632H (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell ICH8M-E (ICH8) LPC Interface Controller LPC Legacy Controller 1 : T0 FC-11h Audio Device : Dell 82801H (ICH8) HD Audio Controller Audio Codec : Conexant 2C06h Audio Codec : Silicon Image (CMD Technology) 1392h Audio Codec : Sigmatel 7616h Serial Port(s) : 2 Disk Controller : Dell 82801H (ICH8) Ultra ATA Storage Controllers Disk Controller : Dell Mobile SATA AHCI Controller USB Controller 1 : Dell 82801H (ICH8) USB UHCI #4 USB Controller 2 : Dell 82801H (ICH8) USB UHCI #5 USB Controller 3 : Dell 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : Dell 82801H (ICH8) USB UHCI #1 USB Controller 5 : Dell 82801H (ICH8) USB UHCI #2 USB Controller 6 : Dell 82801H (ICH8) USB UHCI #3 USB Controller 7 : Dell 82801H (ICH8) USB2 EHCI #1 FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller Network Adapter : TAP-Win32 Adapter V8 (coLinux) (Ethernet, 100Mbps) Network Adapter : Bluetooth Device (Personal Area Network) #2 Wireless Adapter 1 : Dell Wireless 1505 Draft 802.11n WLAN Mini-Card (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows Vista Ultimate 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 3.5 |
sorry, I have the 7.4 LE which I got updated to 8 but it still did not start up. I uninstalled and reinstalled a few times.
7.4. I am having ll these issues on this version at the moment...
1. Again, what interface?
2. You DO realize that you're going to need a physically separate hard drive for audio in order for this to work correctly? A partitioned system drive won't cut it. IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive. Pro Tools supports recording and playback to a secondary drive that meets the following requirements: 7200 rpm or faster 9ms seek time or faster Firewire drives must have the Oxford 911 (FW400 port), Oxford 912 (FW400 & FW800 ports) or Oxford 924 (FW800 ports) Bridge chip. USB drives are not supported and are known to be problematic. |
I was trying to install 7.4. I will take whatever version will work though. Thank you for helping me on this...
I have pro tools le 6.4 with MBOX and i purchased a new WINDOWS VISTA LAPTOP | escay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-20-2010 09:33 PM |
Using MBox 2 as Sound Device in Windows Vista | jwlitster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2010 08:02 PM |
To use Mbox 2 as playback device in Windows Vista | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-10-2010 05:22 AM |
Pro Tools LE M-Box 2 USB Windows Vista Laptop Question | visualvideo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-20-2007 08:10 AM |
PTLE Windows Vista compatible? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-27-2006 10:33 AM |
