#31
Re: Zero Crossing?
1. a) Zero crossing priority for left channel with a preference as to whether subsequent channels zero crossings are selected on the next nearest or previous nearest available crossing. b) When the edit is performed, a region group is auto-created containing all channels. The visible boundaries of the region group conform to the left (priority) channel. c) Trimming the edges of the region group in or out (according to the priority channel) will auto-render the subsequent channels according to the preference mentioned in a). or 2. Instead of creating a region group, the region is automatically given a set of invisible handles that contain fades for all subsequent channels (this way the regions all conform to the same visual boundaries). Any good? |
#32
Re: Zero Crossing?
I use Logic, Wavelab, and Cubase at times... I find the snap to zero-crossing feature quite useful. I'm surprised PT hasn't implemented it yet.
With stereo files, detecting one side is no problem most of the time. The side which is not cut exactly at the zero is usually so low in volume that you wouldn't hear a click anyway. I can't remember an instance where I used snap to zero-crossing on a stereo file and DID hear a click. After that, it's up to the user to be aware of how the feature works and use it responsibly. So...if you're going to do a bunch of edits on stereo files and NOT listen to your work...well, then you're probably better off with fades. I would recommend a simple implementation of the feature, like the other DAW's have. |
#33
Re: Zero Crossing?
Why are you asking for this approach? Are you an LE customer?
...for system configuration info see my profile (Click on member name) |
Crossing over.... | Mike Teezie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 10-28-2002 04:26 PM |
Crossing to the other side PC>MAC | Jayson Torres | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-29-2002 06:43 AM |
Crossing over to Protools...Help. | A.D.D. Kids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-01-2002 05:11 PM |
Edit on Zero Crossing!!!! | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 07-31-2002 09:38 AM |
Zero Crossing | Ke productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-07-2001 02:03 AM |
