  #111
Old 01-21-2020, 02:19 PM
daeron80 daeron80 is offline
Default Re: Pro Tools 2019 + Catalina
Originally Posted by jchan View Post
So hows the performance 2019.12 + Catalina?
Anyone on it?
We have one person on it with a new MacBook Pro that Apple says cannot be downgraded. It's in use by talent who records himself remotely via Cloud Collaboration. Total nightmare. His performance, FWIW, has been fine - he only records VO on a single track, though. But he simply cannot stay properly connected to the Cloud long enough to get something recorded and uploaded. It fails every time, no matter how many times he signs out and back in. We have enabled the appropriate permissions as directed by the tech docs.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
  #112
Old 03-20-2020, 12:54 PM
indieric indieric is offline
We have a new Apple Mac Pro 2019 + macOS Catalina 10.15.3 + Pro Tools HDX Ultimate 2019.12 + SSL AWS 924 Delta console.
It is a little buggy; however, (candidly) I am surprised it works as well as it does. Here is the bummer: the machine takes forever to boot and Pro Tools never launches stating "Pro Tools Not Responding" in the Force Quit window when an Ethernet cable is plugged into the machine. The SSL AWS console connects via an Ethernet cable (ipMidi) to the MacPro. Once the Ethernet cable is unplugged, Pro Tools launches perfectly. Some plug-ins took some workarounds to get going on Catalina (SSL Remote is still not 64-bit; Slate (accessing sound libraries); and iZotope Ozone) but all in all - easy breezy. For those that mix in the box (sans Ethernet control surface) - you're pretty much golden.
At our studio we do not connect the Mac Pro to WiFi when running the SSL console (the SSL AWS gets grumpy when there are things on the WiFi network with it). Hopefully a new Pro Tools update and patch will fix this. We HDX customers have been waiting for the Mac Pro Cheese Grater (with PCI E slots) only to find that a PT Native system is now just as powerful when running on a new Mac Pro Cheese Grater!
  #113
Old 03-20-2020, 03:23 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Have you heard from SSL or iPMidi regarding the controller issues?
ipMIDI 1.7.1 for 10.15.x Posted good.
  #114
Old 03-20-2020, 11:25 PM
JFreak's Avatar
JFreak JFreak is offline
Go to everymac.com to find specs of the model you have. For every mac ever sold they tell you the OS version it originally shipped. Even if it came from factory with a different version, that original release is the earliest you can downgrade.
Janne
  #115
Old 03-31-2020, 12:51 AM
zsarbomba's Avatar
zsarbomba zsarbomba is offline
Originally Posted by jeam25 View Post
Merry Christmas you all Catalina support is here ! As always DO your backup first !!
http://duc.avid.com/showthread.php?t=407652
I downloaded the 2019 Demo version (2019.10.0). It will not load under Catalina. The current release (Not Demo) Appears to be 2019.12.
I was running Mojave & PT11 without issue. I then stupidly, with-out research, up dated to Catalina..
Which means I have lost my "No Contract" PT11 Forever I fear.. Bugger it..
a very big subscription mouse trap slammed shut on my wallet..
  #116
Old 03-31-2020, 12:53 AM
JFreak's Avatar
Avid stopped selling (support and update plan) reinstatements last year, but you might still get lucky with your favourite reseller. If so, you can keep using perpetual license and not forced to crossgrade to subscription model
Janne
  #117
Old 03-31-2020, 03:58 AM
You do have a backup right? Never run without one.
How were you running PT11 under Mojave? The last compatible according to the chart here: http://avid.force.com/pkb/articles/e...tibility-Chart is OSX 10.10.5 although I did have PT 11.3.2 running under Sierra. Had to import audio via drag and drop from Finder though.
Jack
QAPLA!
  #118
Old 03-31-2020, 05:14 PM
zsarbomba's Avatar
^ You are correct my mistake.. Mavericks.. But now its gone so I can't double check.. Hahaha..
Also I am just re-setting up my Studio after 7 years of only the odd tinker.. All PT projects are backed up.. Keen to get back up and running..
  #119
Old 04-01-2020, 04:10 AM
You DON'T have a backup of your previously working system? Carbon Copy Cloner and an external drive make it a breeze to have one.
Jack
QAPLA!
  #120
Old 04-01-2020, 03:40 PM
zsarbomba's Avatar
No I do not.. But I will do this before I get going again...
System 5 with OS X Catalina japple System 5 7 06-27-2020 05:29 AM
Catalina cqd Pro Tools 2019 10 10-09-2019 01:37 PM
Catalina update for Pro-Tools? garnoil Pro Tools HDX & HD Native Systems (Mac) 17 10-01-2019 01:37 PM
Catalina Ryan Young Pro Tools 2019 6 06-06-2019 10:20 PM
