HDX: do I still need to play around with buffer?
I just upgraded from HD Native to HDX on a 12 core Mac Pro.
Part of the reason I made the move was to improve latency when recording. I just didn't want to be bothered to remember to lower my buffer when recording and then raising it again when mixing. But is the joke on me? Now that I'm on HDX, do I still need to worry about the Playback Buffer when switching from recording to mixing? God, I hope not... |
Re: HDX: do I still need to play around with buffer?
What plugins are you using? Got them all in AAA-64 DSP or got some native ones in use as well? (including VIs?).
Well, let's talk with no plugins at all.
When I was running HD Native, I would set my playback buffer at 64 for recording vocals. If I set it higher than that, the singer would complain that "there is a delay". Now that I'm using HDX, can I leave the buffer at like 256 or 512 or will there still be a delay unless I lower it to 64? I do understand that if I'm using plugs, they have to be AAX DSP in order to avoid latency... |
yes. With no plugs, buffer can be set to whatever. The mixer lives on the card and your live input never enters the motherboard.
Pardon me for buttin'n but what about the other scenarios?
So session no native plugs, just a live tracking session? But with AAXDSP plugs on the inserts....a few but def not a mixing session. does your buffer have to be at a low setting to get a good feeling HP mix ?
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
128 all the time, and 256 occasionally?
Or 64 all the time, and 128 occasionally?
With "HDX", 64 has never been stable here with VIs, but 128, and 256 occasionally has been acceptable.
i will check and let you know -- I really change it so infrequently that I don't recall. It may even be 512. for vocal sessions, the only problem I encounter is if I accidentally leave a native plugin active on the master fader.
Currently mixing at 256. On Monday I was tracking at 256 w/ some native plugins (not on the record track, but active in the session).
Play back problems and cannot increase buffer :-/ | johnkuhn | Pro Tools 12 | 8 | 08-09-2016 03:40 PM |
Hardware buffer error that goes away after play-back.. | Nathan W. | Pro Tools HDX & HD Native Systems (Mac) | 0 | 05-30-2014 04:09 PM |
Should I be able to play video at less than 512 buffer? | markblasco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-16-2010 01:10 AM |
M-Box won't play; "Buffer size" error; Dell Lat. D-820 | HOMEBASS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-01-2007 02:53 PM |
M-Box won't play; "Buffer size" error; Dell Lat. D-820 | HOMEBASS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-01-2007 02:52 PM |
