Old 04-15-2017, 08:48 PM
johnnyv johnnyv is offline
Default Best video card for cheese grater Mac and HDX?
Hey all,
I had some hot rod graphics card in my cheese grater Mac Pro that required the extra power source in the Mac Pro. Now that I'm bumping up to an HDX card, I'll need that power source for the HDX, so I'll "downgrade" my graphics card.
I'd still love a graphics card that has at least 1 HDMI output on it. A second HDMI would be nice, but if it's a DVI, that could work, too.
Anyone have a great suggestion for good video performance from a single space, no-extra-power-needed type of card?
Thanks in advance for any info...
J
Old 04-16-2017, 12:06 AM
peterle peterle is offline
Default Re: Best video card for cheese grater Mac and HDX?
there are "y"-power-cables for mac-pro avaiable....
i use one along with ati5870 ( 2 Power cables) and HDX ( 1 cable)
so no need to downgrade graphics - card.
btw which graphics card you use and how many monitors you want?
foley artist , soundeditor
Old 04-16-2017, 01:41 AM
Oh, interesting! I'm out of town at the moment, and I don't off the top of my head recall which exact card I'm using. As I recall, it has at least 1 HDMI (although I think it has 2), a DVI and 2 Mini Display ports.
I have a total of 4 monitors working; one for ProTools, two for client monitors in the Control Room and one in the Recording Room for ADR, etc.
Thanks for letting me know about the power "Y" cable. I'll search one out...
Old 04-16-2017, 08:48 AM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by peterle View Post
there are "y"-power-cables for mac-pro available....
I recently purchased a Mac Pro with an ATI HD 5870. I have a 4K 3840 x 2160 monitor working (at 30Hz) on the DVI port, but am wondering what the max resolution of the DP connectors are. They do not work with the 4K monitor, but they seem to be okay with a 2560 x 1080 monitor (with a DP input).
Just curious as to what your experience has been with the 5870 driving monitors on the DP connections. I assume it will work with the 1920 x 1200 DP monitors, but have not tested the DP connections with the 2560 x 1440 monitors.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 04-17-2017, 12:53 PM
dr sound's Avatar
dr sound dr sound is offline
You can also try this:
http://www.macvidcards.com/store/p78..._and_4_GB.html
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 04-17-2017, 03:38 PM
DetroitT's Avatar
DetroitT DetroitT is online now
Radion HD7950 Mac Edition here working fine.
DVI, HDMI, MiniDP X2
Old 04-17-2017, 09:54 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Originally Posted by panamajack View Post
I recently purchased a Mac Pro with an ATI HD 5870. I have a 4K 3840 x 2160 monitor working (at 30Hz) on the DVI port, but am wondering what the max resolution of the DP connectors are. They do not work with the 4K monitor, but they seem to be okay with a 2560 x 1080 monitor (with a DP input). I tried a DP to HDMI active converter, but that would not display on a 1920 x 1200 HDMI monitor.
These adapters will get you there:
I tested them to 2560.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
IMDB
Old 04-18-2017, 10:03 AM
panamajack's Avatar
I tested them to 2560. . .
Thanks for the tip. I bought a QVS display port to HDMI converter (up to 4K/60Hz Active Ultra HD) that works with a MacBook Pro TB to HDMI (at 60Hz), and got both the 4K monitor and a 2K monitor working simultaneously with the 5870 in the Mac Pro. The 2560x1440 monitor works fine direct with the DP connector, and the 4K monitor works on the DVI, but at 30Hz. The DP to HDMI converter will also display on the 4K monitor, but only at 30 Hz.
Old 04-20-2017, 02:10 PM
djjazzy41 djjazzy41 is offline
I'm using the Sapphire HD 7950 Mac edition video card (it does take two power connectors). It is pushing a full 4K @ 60Hz main monitor from one of the MDP ports with the use of a full 4K MDP-DP adapter. The video card can be found here: https://eshop.macsales.com/item/Sapphire/100352MAC2/
The Y cable for splitting power from my Mac Pro's board to cover both plugs on my video card is this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Everything works perfectly; full 4K to the main monitor, no problems feeding the 2nd monitor, and power to the HDX card. As the others have said, hopefully this solves your problem. Just wanted to provide the links to the stuff I used successfully.
Originally Posted by The Egg: Be a Pro and stop being a Tool!
Mac Pro Rack (7,1) 16-core 3.2gHz Intel Xeon W
OSX Catalina (10.15.4)
8TB Mac OEM SSD System Drive
(3) 1Tb 7200rpm audio hard drives
192Gb RAM
Radeon Pro Vega II Video Card
2 Avid HDX Cards
2 Avid 8X8X8 HD I/Os; 2 Avid 16X16 HD I/Os
PT Ultimate 2020.3
Old 04-21-2017, 03:57 PM
Hey thanks for all the useful info, everyone! I've ordered some of the convertors and Y cables mentioned above.
Awesome!
Thanks,
J
A little Whine and Cheese... lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-20-2008 11:54 AM
I like cheese! Anyone got a plunger? c.evans Pro Tools TDM Systems (Mac) 8 10-20-2006 03:02 AM
Here comes the cheese.... 3JDamon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-14-2004 05:09 AM
Whine with my cheese? ladewd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-01-2003 11:53 AM
BEST CDRW to put in new Cheese Grater? Lee Blaske Pro Tools TDM Systems (Mac) 5 09-13-2002 09:05 PM
