#21
Re: Alternate techniques for De-Essing
clip gain is the best feature of PT10 hands down.
Windows 7 64 Ultimate: SP1 PT 10.3.8 ------------------------------------------------------ ¨WHERE´S MY CHECKBOOK?¨ https://soundcloud.com/louieshowers |
#22
Clip Gain is superior because it's pre-fader or plugins so any compressors on the channel are never seeing the loud ess sounds as they're lowered before they get there. I didn't even know this was a sticky.
Pro Tools Tutorials: Mixing Heavy Rock & Metal • Pro Tools 11 - Tips and Tricks • Delay Explained • Tracking Rock - Drums • Mixing Rock • Music Production with Pro Tools • Pro Tools Tips and Tricks Vol. 2 • Pro Tools Tips and Tricks Vol. 3 • Elastic Audio in Action |
#23
Another de-esser trick...just have your vocalist sing in Hawaiian...there's no "s" sounds in Hawaiian...so you won't have to deal with it at all!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
#24
Try the Deesser from Eiosis! Thats a superb deesser, it "cuts" th esses out... Try it!
K |
#25
Wow! Thanks! You just saved me like hours... I have 15 songs I'm de-essing, and I had already cut the regions up and was about to start volume automating and then I saw this. Big time saver. Just put trim on bypassed, turn bypass off for the esses, boom. Don't even have to specify volume, just leave it set at 3db or so, all your esses are good to go!
#26
But seriously... If you have more than 2 backing vocals - let one of them sing with "s", and others just have to skip "s-z" altogether. Then you have to deal just with the main one :) I tried this with group of 5 backing vocals sitting one on another - worked perfectly!
System Details: Host: iMac 27" QuadCore i7, 3.4GHz/32GB RAM/768 GB size internal SSD HD. OS X 10.8.3. Interface: Avid Mbox 3 Pro. Monitoring: Yamaha HS80M + Avantone MixCubes. Two external HD (7200 rpm, 64 cache): Buffalo DriveStation (for audio projects) + OWC Pro (for instruments' libraries). Instruments and plugins: NI Komplete 9 and East West Complete Composer's Collection 2 and other. Moved from Cubase 3 to PT10+MboxPro. Very happy with PT10! |
#27
duc tape the singers tooth gap's. Or get them to chew chewy sticky fudge to fill the gaps before singing.
#28
FabFilter de-esser or just split the waveform and lower the esses
PT 2018 HDX 1 Mac Pro Westmere 12 core 3.46 OSX 10.12.5 64 gig ram |
#29
If you got the time clip-gain is definitely the way to go.
Any D-esser plug in will do the job quick & dirty; Waves is good, Massey is great, even the on-board good ol' Digidesign plug is quite good. I've been using Brainworx's Dynamic EQ with very good results. Frequency specific (multiband) compressors are also worth experimenting with, these could be anything from the CLA-2A (with some tweaking of the Hi-Freq control) to something very sophisticated like the Waves C4. If everything else fails; strap a pencil across your LDC with a rubber band...
"Don't look; listen!" At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6 At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1 |
#30
Mic placement.
De-Essing......where in the chain? | jlcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-27-2013 08:45 AM |
De-essing | Notefarm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-21-2004 09:34 AM |
De-essing Vocals | skylab001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-15-2004 01:11 PM |
Hand de-essing tips please! | Jules | Tips & Tricks | 21 | 04-02-2003 01:52 AM |
De-essing With Digi???? | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-25-2002 11:17 AM |
