Old 07-02-2020, 03:44 PM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is offline
Default Re: Just one more driver update for macOS Catalina!
Originally Posted by BCnSTL View Post
I'm curious - does rig-embed work? I had thought that only worked when the 11R was your primary audio interface.
Yes, if you’re sending a digital signal. If you’re sending analog signals, no.
I’ve never used 11R as primary, yet have always been able to embed rig settings. You just need to tell Pro Tools which input is sending the rig.
I have NEVER had the aforementioned midi error message. 11R editor has always worked as it should. In fact, it seems to be a little snappier on 10.15.5
11R driver no longer works in 10.15.5 but it isn’t really needed even to record digitally.
Check out the posts starting with this one forward. http://duc.avid.com/showpost.php?p=2570996&postcount=51
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Eleven Rack Compatibility with MacOS Catalina guijacobucci Eleven Rack 87 07-21-2021 07:30 PM
PT and Latest macOS Catalina (10.15.4) rinky Pro Tools 2020 3 04-29-2020 01:12 PM
PT 12.5 and macOS Catalina johnbarnesiii macOS 12 12-20-2019 03:02 PM
Can EuControl 19.9.0 be used with MacOs 10.15 Catalina? hanksinclair Artist Series 2 12-09-2019 10:54 AM
macOS 10.15 (Catalina) and Avid Products Avid Technical Alerts 0 10-07-2019 11:11 AM
