Old 11-20-2001, 11:24 AM
doctor j doctor j is offline
Default Removing Reflections-drying off a wet mix
Hi-
A client just brought in a poorly recorded concert on mini DV, and wants me to clean it up
The audio is a live mix in the middle of a large Las Vegas Showroom, so it is totally wet and reverberated.
I tried rolling off some of the high end, and running the whole mix through TC Master X, and that does crisp it up a bit, but it is still pretty bad. Plus, rolling off the high end makes the mix a little muddyer. I told him that it is pretty much unsalvageable, but i figured i would check and see if anyone has any other ideas.
thanks,
j
Old 11-20-2001, 05:35 PM
Corey Shay Corey Shay is offline
Default Re: Removing Reflections-drying off a wet mix
Maybe try some expansion? Multiband expansion like C4? Haven't tried it myself, I was just guessing. I'd imagine it could reduce some of the reverb decay.
Old 11-21-2001, 10:10 PM
That's a good idea. I really love the C4. I just started using a few weeks ago, and it sounds great. Now I want to use it on everything.
As far as deveberating, I ended up putting the mix through the ultramaximizer, and that seemed to push the source sound forward a bit. But overall, there wasn't much of a difference. The recording was just too damn wet.
Thanks anyhow-
j
UAD2 + Win 7-64 + ProTools 9 Reflections vonglahnpg Windows 6 05-26-2011 07:55 AM
Removing a group funkypaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-29-2008 03:05 AM
VSS3 Reverb is disregarding its Early Reflections LOW CUT 25ghosts Pro Tools TDM Systems (Mac) 0 03-07-2008 01:14 PM
removing d-fi pop-up ads mr_dude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-30-2005 04:36 AM
removing measures Rhett Redelings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-20-2002 12:39 AM
