Old 12-16-2000, 09:40 PM
Dillo1 Dillo1 is offline
Default Having trouble syncing Digi001. Please Help!
I would like to sync my Digi001 to either my Roland VS-880's, or my ADAT's. I've been using the MIDI from the 880's which will start and stop ProTools, but ProTools won't match its time code to the 880's. I can't seem to find the trick. Any suggestions?
Old 12-17-2000, 08:12 PM
PVONTE PVONTE is offline
Default Re: Having trouble syncing Digi001. Please Help!
hi i'm using a 1680 and it works fine . you can use either one as a master ...check out the window pull-down under show seccion pref. also make sure that the starttime ( in pt) is set to all 000000's..( the default is set to 01....or one hour!) good luck...pvonte
Old 12-21-2000, 10:04 AM
cyberstudio cyberstudio is offline
IF YOU JUST SET UP EVERYTHING USING YOUR MANUAL AND YOU ARE SURE 880 IS TRANSMITTING MTC, ONE MORE HINT:
Can't get MTC into In Pro Tools LE 5.0.1 for Win98
In the Peripherals menu, the Generic MTC Reader port setting must be set to Any. Switching it to the specific device which is actually sending MTC will not work.
This is a known bug in Pro Tools LE 5.01 for Win98
FOUND ON DIGIDESIGN WEB ANSWERBASE
c y b e r s t u d i o
P O L A N D
Trouble Syncing Drum Machine with Pro Tools scottrolfs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-24-2014 06:49 PM
Trouble Syncing Akai MPC500 with PT M-Powered 7.4.2 eXeMt MIDI 5 07-11-2008 07:32 PM
Trouble syncing 002 PT LE to M-Audio interface mcmclaren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2006 02:40 AM
Trouble w/ MTC syncing PT LE 6.2.2 (Mbox) to 1680 motord 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-27-2005 09:23 AM
Trouble syncing Logic To PT JLEpperson Pro Tools TDM Systems (Mac) 1 06-02-2003 11:24 AM
