Old 03-25-2024, 12:55 PM
IrelandM IrelandM is offline
Default Eucon Status
Hi There,
Trying to get my Avid S3 to connect to Eucon but the status light remains dimmed running ProTools Ultimate 2024.3.0 on macOS Monterey 12.4 and
Pressing the configure Eucon tab the status bar moves to over halfway then it hangs and I need to force quit EuControl or ProTools.
Is it advisable to have Auto-launch Apps enabled on startup also is the IP address self assigned.
Regards
Old 03-25-2024, 01:01 PM
Iain Haworth's Avatar
Iain Haworth Iain Haworth is offline
Default Re: Eucon Status
Do you have PT in the Application list in EuControl Settings? If you had this in the list for PT 2023, you'll need to remove this and add PT 2024 (we've fixed this in our next release so the DAW name is generic)
Iain
Old 03-25-2024, 01:20 PM
Hi Iain,
I do not have PT in the application list in EuControl settings. Cannot add PT 2024 as the plus tab does nothing in the Last Focused Application this is just blank.
Regards
Old 03-25-2024, 01:45 PM
Can you describe your system/computer setup including what version of EuControl you have installed?
Old 03-26-2024, 08:23 AM
EddieJones's Avatar
When anything weird like this happens its always best to run the EUCON installer again, check remove all Apps and remove all prefs. Restart and then install EuControl (top option) again.
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
System Status vs. CPU Status Chence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-25-2003 12:40 AM
System Status and CPU Status - Please Help Chence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-24-2003 03:54 PM
