Old 03-24-2024, 11:00 AM
Steve Db Steve Db is offline
Default Echo on new session
Hi. When I open a new session there's this horrendous echo or reverb that shows up on the click track, default groove cell, and anything I record. The last time it happened I uninstalled PT and re-installed it, and it was OK. I only open it every month or so and now the problem has returned. Anybody encountered this and have an idea of how to solve? Thank you.
Edit/update:
I'm using PT Artist on Windows 11.
Just got this error message: "Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue. If this occurs often, verify your sync cables or try changing the HW Buffer Size setting in the Playback Engine dialog. In most cases, a larger HW buffer size will prevent the problem. (AAE -9093)
When I set buffer to 1024 the echo decreases but is still there.
Old 03-24-2024, 11:04 AM
its2loud its2loud is offline
Default Re: Echo on new session
You haven’t provided enough information about your setup to determine a cause.
This is most likely a routing issue or doubling up of monitoring between Pro Tools and your interface. More info is needed.
Old 03-24-2024, 01:06 PM
junkgear's Avatar
junkgear junkgear is offline
Welcome to the forum. It does sound like a setup or configuration problem, maybe both. Unfortunately without any information about your setup including the audio interface you are using, it’s difficult to offer possible solutions besides guessing what might be happening.
Please read through the Help Us Help You thread, where you will find general setup, troubleshooting and posting system information instructions.
From what you have posted, it would seem like whatever you are using as an interface can not process audio quickly enough. Without more information, it’s hard to guess why.
Will
System Details
WTB: Echo Boy danander11 Buy & Sell 0 05-05-2016 05:30 PM
Echo Express III and Echo Express Pro (HD Cards) Barry Johns Pro Tools HDX & HD Native Systems (Mac) 2 04-26-2013 07:37 AM
Anyone else here the echo in the DUC? KroNEe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-23-2010 02:04 AM
Echo FredFarmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-02-2006 11:35 AM
How to get Echo . . . Echo . . . Echo . . . TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-12-2006 07:27 AM
