Reverse reverb not working?
Since maybe an update or two ago, the reverse reverb function in AS does not seem to work, regardless of which reverb I choose: it generates it, but than reverses it again... Anyone else noticing this?
This is on 2022.12 Ultimate on Mac (Catalina). |
Re: Reverse reverb not working?
Is "Use In Playlist" turned on?
Also check the Selection Reference setting... https://resources.avid.com/SupportFi...df#G53.1227025
• linkedin •
Can I be ashamed for a moment?
I simply misunderstood (or forgot) that in order to have a reversed tail, I need to select space before the clip and not after (as what you would do with a regular verb). Pretty darn stupid. Thanks for your replies: although all was set correctly, it *did* help in figuring our where I was messing up... Have a good weekend! |
My favorite new feature, Reverse Reverb/Delay Audio Suite PT 10 | Dizzi45Z | macOS | 2 | 10-26-2011 04:23 AM |
reverse reverb effect | SublimeAndy | Tips & Tricks | 4 | 04-12-2008 01:50 PM |
Reverse Reverb | cpnraisnuts | Tips & Tricks | 6 | 05-17-2005 11:34 AM |
How do you make a reverse reverb effect? | deejfro | Tips & Tricks | 2 | 02-13-2005 09:24 PM |
Reverse Reverb for Ld Vox | Armando | Pro Tools TDM Systems (Mac) | 5 | 11-13-2001 09:02 PM |
