Old 05-14-2016, 05:58 AM
amolin amolin is offline
Default Layouts are disappearing
Maybe I'm wrong here, but I thought Layouts was saved with the PT session?
Yesterday I created some layouts in the first session I'm mixing on the S6, when I opened the session today the layouts was gone...
Am I missing something, do I need to seve the layouts "manually"?
S6 2.11, PT 12.4
Old 05-14-2016, 06:57 AM
tamasdragon tamasdragon is offline
Default Re: Layouts are disappearing
Few things to check.
1. Is the main daw selected on the S6? If for some reason someone select another daw, or switched back to internal saving, it won't be saved with the session.
2. Are you absolutely sure that you hit store? No offence, but sometimes I simply forget to store the layout
3. You may try to check the daw selected in the Workstation tab on the S6, then quit PT and relaunch it to see what happens. I only had one layout missing, but this solved the issue.
my blog:Tamas Dragon
Old 05-14-2016, 07:34 AM
PT was not the designated DAW, I selected it and now it seems to be working :)
Thanks, you got me in the right direction.
Layouts beyond modules brdst Avid S4/S6 4 09-23-2015 11:27 PM
S6 V1.2 Layouts features bucha Avid S4/S6 3 07-06-2014 04:19 AM
Layouts Reckless Erik Artist Series 6 09-17-2013 07:21 AM
Layouts In Flux Dsturzy VENUE Live Sound Systems 0 03-16-2013 07:27 PM
using Layouts from project on another? fork-media Artist Series 2 07-13-2012 04:12 AM
