Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 04-09-2016, 05:30 AM
T'n'T T'n'T is offline
Default Fast Track C400 not detected
Hi.
I have been using the fast track c400 for a couple of years with pro tools 9 on windows 8.1. It has been working fine until yesterday. Windows doesn't detect it all of a sudden. I have had this problem before, but then I pulled out the usb cable and inserted again, then it would work again. That doesn't help now. I have also tried removing and reinstalling the newest driver (and older drivers as well). Restarting the computer... Nothing helped.
I noticed that the power-light on the fast track is pretty week. It didn't use to be like that. When I tried the usb 3.0 port it said there wasn't enough power to run the device. I normally use usb 2.0 for the fast track.
Could it be that there is not enough power to run it all of a sudden? Any other suggestions?
Any help is much appreciated. Thank you!
Old 04-11-2016, 07:21 AM
JoelG's Avatar
JoelG JoelG is online now
Default Re: Fast Track C400 not detected
Can you test the C400 on another computer? Also, try another USB cable.
Please post your full system specs too.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-11-2016, 09:29 AM
Hi Joel
I tried the c400 on my older computer, and the lights on the c400 flashed to indicate that there wasn't enough power, though it used to work just fine on the old computer a couple of years ago.
I haven't tried another cable yet (I don't have another usb A -> usb B cable).
Here are my system specs:
http://speccy.piriform.com/results/I...M1JcGZo4d3SLpn
Thank you :)
TT
Old 04-11-2016, 10:30 AM
JoelG's Avatar
Make sure you're using the latest drivers here:http://avid.force.com/pkb/articles/d...k-C400-Drivers
If it doesn't work on another computer, with a different USB cable then I'd suspect a hardware failure. If that's the case, you'd either have to get it serviced or find a replacement (probably cheaper).
Joel
Jam Space:
Home:
Rig:
M-Audio Fast Track C400 Dunkin1953 FireWire & USB Audio Interfaces (Mac) 2 03-15-2016 09:49 PM
Fast Track c400 issues (help) stereopole FireWire & USB Audio Interfaces (Win) 8 01-11-2016 05:53 AM
PT10.3 and Fast Track C400 frcjt macOS 2 09-16-2012 10:07 AM
Problems with New Fast Track C400 maestrochase Pro Tools M-Powered (Mac) 2 01-17-2012 03:49 PM
Fast Track c400 Suddenly Clear Pro Tools M-Powered (Win) 3 10-29-2011 02:17 PM
